996 Clutch or Pressure Plate failures - Anyone ?
Old 02-20-2010, 03:20 PM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Originally Posted by bobt993
Not me, but Darren is running a 996.
Oh, right. He'd be pretty upset after all of the work he's done on it.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 02-20-2010, 03:24 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,719 Likes on 883 Posts
Originally Posted by Premier Motorsp
Well, I guess you'd be the one who would know.
Hahaha! Nah....but I read it on the internet, so it must be true, right?
Professional Racing and Driving Coach
Old 02-20-2010, 06:07 PM
jrgordonsenior
jrgordonsenior's Avatar
Originally Posted by drbooba1
What happens is the pressure ring which is the steel component the straps index moves off center due to either mechanical backhole or excessive RPM, usually a hell of a vibration occurs at the same time, next the straps break and the buzz saw occurs. The early Cup cars came equiped with the Sachs street strap set up of only 2 bands and they were a big problem, once at a cup car race I saw a team go through 3 pressure plates in one weekend event. You must use 3 straps even on the push type diaphragm set ups.
regards
Sort of like this?....
Old 02-20-2010, 06:24 PM
trackjunky
trackjunky's Avatar
Hmmm. Is that off your 996Spec?
Old 02-20-2010, 07:01 PM
Larry Herman
Basic Site Sponsor
Ecch, that's fugly.
Old 02-20-2010, 10:37 PM
jrgordonsenior
No it was the only major mechanical part that broke on my 03' cup in 4 years (140 hours) of racing....
Old 02-22-2010, 11:24 AM
onefastviking
onefastviking's Avatar
Similiar. No center ring moving, just breaking either the drive straps or the rivets that hold the drive straps, then the buzz saw effect occurs.
Old 02-22-2010, 11:29 AM
onefastviking
What happens is the pressure ring which is the steel component the straps index moves off center due to either mechanical backhole or excessive RPM, usually a hell of a vibration occurs at the same time, next the straps break and the buzz saw occurs. The early Cup cars came equiped with the Sachs street strap set up of only 2 bands and they were a big problem, once at a cup car race I saw a team go through 3 pressure plates in one weekend event. You must use 3 straps even on the push type diaphragm set ups. Any hot rod clutch shop can change them for you. Sachs also has the correct Pressure Plate you just have to make sure they give it to you.
regards
Yep, I have already spoken to Sachs about it. Already have 3 straps on it but I am not sure they are strong enough.
Old 02-22-2010, 11:30 AM
drbooba1
drbooba1's Avatar
Always buy the 3 strap Pressure Plate (better but no guaranty) or switch to Tilton
regards
Old 02-22-2010, 11:34 AM
onefastviking
I am not entirely sure what parts were in there when the failure occurred but I sold the car with a Cup diff, lightweight flywheel, and race clutch just as you describe.
I guess that the pressure plate explodes when it gets torqued strongly in 'wrong' direction (ie wheels driving engine) even if the engine is not overreved.
These cars just don't seem to be as tough as the older Porsches and GT3s are. It is really to bad, since they are cheap and plentiful, and the chassis is pretty damn nice.
Chris Cervelli
Spline Technologies
Thats pretty much it. I think they just underdesigned the PP for the 996/Boxster engines. Let me clarify that, they designed them fine for street use but not for harder race use. With the stock setup I think you just toast the disc, but with the changes we make for racing the clutch disc grabs rather than slips and then you end up breaking drive straps.
By comparison, look at the thickness and size of the drive straps and rivets on a 993 or even 3.2 911 Pressure Plate, they look about 30% thicker/larger/stronger.
Old 02-22-2010, 11:39 AM
onefastviking
All I have ever used is the 3 strap, blown 2 so far !
Don't want to switch to the Tilton, afterall this is just a stock motor 996 only running in NASA GTS3.
regards
Old 02-22-2010, 06:09 PM
magnetic1
magnetic1's Avatar
Dunno the exact makeup of the Porsche plate, but the BMW's are notorious for snapping those straps. A bunch of racers have used a place called Ft. Wayne Clutch in Indiana. You can get those straps upgraded and it is fairly cheap.
http://www.fortwayneclutch.com/
Old 02-22-2010, 06:57 PM
Veloce Raptor
+1. This happened at least 2 dozen times with our Grand Am Cup 330ci.
Old 03-18-2010, 09:06 PM
airplayn
airplayn's Avatar
I just had a catastrophic failure of the pressure plate on a replacement Sachs clutch I put in my 328iC last year. It looks like on of the straps failed and the pressure plate shattered tearing a hole in my bell housing. I have seen posts as old as 2007 complaining of this problem and there is a VW technical bulletin out on failure of defective Sachs clutches. Has anybody got any response from Sachs on covering this type of collateral damage caused by their defective strap holding the pressure plate to the cover?.
Old 03-18-2010, 10:05 PM
magnetic1
magnetic1's Avatar
Good luck with that...
Before you put another in, get the straps reinforced from the place I listed above.
Quick Reply: 996 Clutch or Pressure Plate failures - Anyone ?
