Lubrication Engineers Oil - anyone using it?
4th Gear
I have a 1993 911 Porsche RSA stock race car and am currently using Brad Penn semi-synthetic oil. I was thinking about switching to Lubrication Engineers 8800 oil which they tell me is better than Brad Penn. Anyone have an opinion on this?
*Finally*! I wondered when someone would hire some lubrication engineers to
make a motor oil.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Oil can be a religion, as you probably know. That's because most people
get by with whatever they are using. If there was a clear winner/loser it
would be obvious. If you stick to the motor manufacturer's recommended
viscosity for your environment/use, and use any top-shelf oil, and change
it as frequently as your use requires, it would be a rare and specific case
where anyone could factually argue that there's a better way.
make a motor oil.
I have heard that they make some amazing gear oil. But I don't know which models, they also may make some secret oil that you can't get? (NASCAR)
Their website may be out-of-date, but all they list that may be
relevant is in their generic passenger car oil section. Doesn't
sound special to me...
http://www.le-inc.com/
PASSENGER CARS
8130™ MONOLEC® ULTRA-BLEND Engine Oil
A heavy-duty, SAE 10W-30 engine oil designed for all-weather performance in gasoline and diesel engines. All season performance for effective cold cranking at low ambient temperatures and excellent performance at high temperatures.
8530 MONOLEC® SPB ™ Engine Oil
A high quality SAE 5W-30 synthetic-paraffinic blend engine oil designed for today's passenger cars and light duty trucks equipped with gasoline engines.
PASSENGER CARS
I used it all of last season. It was recommended as the absolute best by Guards when I installed one of their dif's last winter. Paul Gaurds said that he had seen a big difference in Porsche transmission that used Lub Engineers product vs. others. No complaints. Contact one of their reps, if you need any other information I should have it in my home office.
I got my oil from here: http://www.mag-hytec.com/store/
Yes, we do recommend LE gear oil. If they are making engine oils I would suspect that they are just as good.
Regards,
Matt Monson
Guard Transmission LLC
Regards,
Matt Monson
If all they make is a 5 or 10w/30 then it's no good for most of our cars though. Unless they make other weight oils too?
