Trailer servicing
Do it yourself! Not much there. Brakes, repack/replace wheel bearings. Rotate and balance the tires and you should be good to go, so to speak .
Alignment? I wonder how that works on a trailer. I think they have straight axels. Guess I should take a look at my owner's manual.
Edit: If you can cut Fred's roof out with the torch you can do this.
Talk about a time consumer, that is a major project.
Eastwood is surely your friend. They probably recognize your number on caller ID.
Good luck with the trailer and the car.
HERE is the Dexter Axle tire wear guide.
If anyone in Eastern Ontario/Western Quebec needs trailer servicing my company does it as well. We do lots of them. www.primotrailersales.com
NASA Racer
Even with EZ Lube you should still repack the bearings periodically. And use new seals each time. In Ontario a trailer safety inspection is mandatory on an annual basis. Frame, Tires, Lights, Brakes etc. are all checked. There is a recommended maintenance schedule from Dexter Axle.
Best place to go is to Pearl River, NY. They serviced my enclosed trailex beautifully. Steve at Central Avenue Service is a super nice guy. Would highly recomend.
