Track Worthy C4S Rotors
#31
* Direct Replacement – Use With Stock Calipers And Pads
* Cooler Temperatures To Reduce Brake Fade And Increase Disc And Pad Life
* Reusable Hats For Lower Disc Replacement Costs
* Full Floating 2-Piece Assemblies With Billet Aluminum Hats For Lighter Weight
* Save Up To 16 Pounds Per Car In Un-Sprung Weight To Improve Handling
* Low Cost Direct Replacement For PCCB Equipped Cars
Brembo Type III 2-Piece Floating Disc Assemblies Are Engineered For Maximum Thermal Capacity To Increase Durability And Offer Increased Cooling To Prevent Premature Cracking. The Unique Slot Pattern Constantly Refreshes the Pad Surface And Offers Better Initial “Bite” You’ll Notice the Improvement In Daily Driving And At The Track.
NOTE: †Vehicles With 4-Piston Factory Calipers
#32
Former Vendor
Use Motul RBF600 at a minimum.
Holed rotors used on the front of a tracked Porsche....cracks and grooving will occur WAY before they actually wear out.
When was the last time you saw a professional race team use holed rotors? They D O N ' T ---
JSasportas here on Rennlist got 27 days from a set of GiroDiscs on his GT3. 27 HARD days.
