Braking, when do you have enough?
This year I upgraded my car from 924S spec (nearly) to 951/968 spec all around. Couple this with an increase in tire/wheel size from 245/15 to 275/17 and my braking has increased dramatically. Last year my major competitor was able to out brake me with ease, this year I can out brake him (and many others). However, a few of my fellow drivers think I can do even better with the addition of 951S front calipers and rotors. Any informed opinions?
Other info that might be of interest.
Car - see avatar.
Car/driver weighs in at 2640 (currently porky, will be 2510 for next season).
Brakes pads are Hawk DTC60 all around and is well balanced, front rotors have cooling ducts, rears do not.
Tires - Hoosier R and A6's.
Car - see avatar.
Tim-
I have the 951S (928 S4) set up in the front and love it. With the 245's up front it provides me with a fairly balanced package. I also upgraded (changed) the brake bias valve to the 951S with more rear bite.
My car weighs 2650# and I don't have the 968 power (yet) so given your configuration I would definitely say it would be worthwhile.
Tim-
I'm running solid frozed rotors with PF97 pads.
I can get 4 or 5 weekends out of the pads. Maybe even more. I don't really keep track as I just have a spare set in my trailer and put them on when needed.
The frozen rotors have lasted a season and a half.
Basic Site Sponsor
Basic Site Sponsor
When you can still lock the front brakes (or trigger the ABS) at the end of the stint, if the brakes remain consistent once they get up to temperature, if the pads and rotors last a reasonable amount of time, then I'd say you have enough brakes. Any more (larger calipers & rotors) will not stop you any faster, and will just add weight.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I already have the calipers, found a good deal that I just couldn't pass up earlier in the year, you know, just in case I still have to buy the adapters, rotors and pads. I guess it's just money
Is there any advantage of moving the front 968 brakes to the rear? Although they use the same pad, the front calipers have larger pistons.
more unsprung mass is bad. However better braking is good.
the question is does the increase in mass counter the braking? Like Larry said braking performance is mostly about heat managment. Larger rotors and pads allow you store more heat to keep overall temps down. Slowing down better is a result of braking and other things. Pads, Pad thickness (new vs old), operating temps, tire contact patch and as result suspennsion settings.
You maybe able to improve braking by changing the alignment and or spring rates. Larger brakes in front won't change that (except for unsprung mass), but wil give you more heat capacity.
Also, the calipers are physically larger, the rotors are thicker and have directional vanes and the pads are quite a bit bigger, so they will absorb/dissipate more heat and be more fade resistant than what you currently have.
I recall the caliper bolt pattern is not the same front to rear, so the fronts cannot be mounted on the rear trailing arms without some sort of machined adapter. I am not aware of any off the shelf adapters available to mount front calipers on rear trailing arms, but they might be out there somewhere.
