OEM Solid Rotors for 997S (ie: 996GT3 using Cayenne rotors)?
"Pad swapping is actually easier as there's an extra millimeter of space on each side of the caliper..."
"... the total offset moves in towards the car by 2mm"
Great write up. Little uncertain about the 2mm difference - does the rotor appear centered or does it offset toward inside of hub as second comment sounds (which would seem to put the extra space for pads on just the inside)?
Will be very interested in how durable you find the rotors to be. I get 18-20 tracks hours (10 or 12 days depending on session times) on the OEM disks before the cracks require replacement.
Thanks for sharing your experience!
Ron, I'm not sure of the part #'s...I bought them from Suncoast and they are the base Cayenne front rotors. There is no sign of any pad build-up at all. I'll try to snap a pic tonight or tomorrow.....I've actually gotten kinda used to them
Regarding the other ?'s:
" sorry, but if the heat up faster and stay hotter... how are they performing the same??"
They heat-up a little faster so they actually feel a bit more grippy at the beginning of a session. The staying hotter longer part is just what I've noticed while taking temps in the paddocks between sessions.....they hold heat longer. My lap times are no different then with the stock rotors (low to mid 2:30's depending on traffic) and the feel is the same as well.
"Little uncertain about the 2mm difference - does the rotor appear centered or does it offset toward inside of hub as second comment sounds (which would seem to put the extra space for pads on just the inside)?"
Good Question.....they appear centered but I'm not really sure. My pagid yellows only had one DE day before I installed them with the new rotors and they fit fine on both sides (they are very thick when new). Unfortunately I don't have a solid answer for this.
"Will these work on a nonS 997 as well?"
To the best of my knowledge, they will not work with a non-S due to the use of different rotors and calipers.
Googled metric conversion to learn 2mm is less than 8/100" - no wonder it is hard to tell!
Will be most interested to hear how these hold up to track usage - sounds very encouraging!
Thanks again.
Thanks again.
In any event, I switched to GiroDisc Slotted rotors a few months ago and have been happy them overall. Of note, they are a bit sensitive to pad transfer if you switch between stock pads and track pads, however, the vibration goes away after a couple hunderd miles after switching back to street pads.
Hope that helps....
I used them for 4 or 5 events and they started to give a pretty bad vibration in the steering wheel and brake pedal under deceleration. I'm not really sure if they warped or had pad transfer/run-off/hot spot issues (as I switch between stocks and pagids). Regardless, I gave it a few hundred miles and it didn't go away.
Hope that helps....
Hope that helps....
