The SmartyCam is now available
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
After a long wait they are finally here.
http://www.smartycam.com/index_eng.htm
If anyone has any questions feel free to send me a message. I should have one out at VIR for the member days this weekend.
Thanks to a hacker my online store is currently down. If you're interested in one please contact me by PM or email and we can process your order.
Thanks.
Thanks.
Finally!
Am I right its not HD (which isn't necessarily a problem)?
Any experiences with the optional external mic?
Lets just say I wanted it delivered to MA by Monday; is this possible?
And finally - if I am going to connect to my AIM MXL Pista for data and power, is there anything I need other than the camera as shipped? I already have an I/O Port mount.
Here are the tech specs, not bad... wonder why the Brake input isn't working in the couple videos that show it?
Technical characteristics
Dimensions 122x47,5x46,5mm
Weight 210g, battery included
Display size 128x160 pixel
Waterproof IP67
Lens Multi-element glass lens with infrared filter
Diagonal field of view 94°
Focal length 3.88mm (equivalent to 24mm in a 35mm camera)
Internal battery Rechargeable lithium battery – 2.000 mAh 3.7 Volt
Battery charge Via socket/CAN: max 700 mAh
Via PC: max 450 mAh
Battery duration Up to3 hours acquisition
External power 9-15 Volt
Memory Up to 16 Gb
Memory capability 1 hour recording = 1 Gb
Movies format H.264 -720x400 pixel @ 30fps
F/# F2.6
Accelerometer tri-axial ± 5G
Usage temperatures -20°C/+60°C
Auto Power ON Yes, if connected to an AIM logger
Auto Power OFF Yes
Auto Start/Stop Recording Yes
Waterproof IP67
Via PC: max 450 mAh
Memory Up to 16 Gb
F/# F2.6
Auto Power OFF Yes
Hi Gary
Since you seem to know what this stuff means - what do you think of the 'movie format' specs? Since its just for personal use and Vimeo-type streaming, I don't think I 'need' HD.
I'm no expert Rick, but to say you "need" HD, no. At this point it's the least expensive way to directly integrate data/video from AIM.
Last edited by Gary R.; 09-24-2009 at 01:21 PM. Reason: Original was a rant and not fair to Joe..
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Finally!
