911SC Headers - please help
I just removed a set of pre-74 heat exchangers and Monty 2-in 2-out muffler from my 1980 911SC. When I installed these, I had to back-date the oil lines. Now I am trying to install a set of used headers that look very much like European Racing Headers, which I will run with megaphones or shorty mufflers.
So, the problem is the front, highest pipe of the header on the passenger side wants to share space with the back-dated oil line that runs in front of the oil cooler and under the bell housing. Can I go back to the original oil lines or will they conflict somewhere else?
Steve and Josh,
Thank you very much. Steve, you last picture is just what I needed. Your highest pipe is in front of the oil line. Mine hits it there. My headers must be copies, or another brand.
Josh, your pictures show me that I can go back to the original oil line setup and be fine. And waht are all those screws and bolts through your passenger floorboard? I hope to be able to make the NASA race at VIR in October.
Don
Don
