Great Performance Driving School on TWS on Aug. 15, 2009 - Thanks Misty!
Yesterday, I had my greatest day on the track. I have done about 8 DEs and signed up for a 1-day event for solo drivers that was run by TWS. Because the number of participants was about 25 they did not follow a run group schedule and changed it to 8 sessions a' 45 min with 15 min breaks in between.
In the Texas heat (close to 100) this was a lot of track time. I did 7 sessions with about 30 min. each and it was a blast. I had enough time to "play around" and learn my new car. I was a little bit concerned about the "corner passing with signal" because I am fairly inexperienced in blue solo compared to the race drivers. However, there was not a single passing issue I experienced all weekend long and I felt very secure.
This was by far my most fun day on the track and I would like to thank Misty and her team. Way to go! I will be back.
Erik
Erik
The Penguin King
I was at this event also and had a great time. It was exhausting. I figure I spent nearly 4 1/2 hours on the track.
As far as the passing, it was open passing with a point-by. All of the advanced drivers were well aware of the mixed levels of experience, and we (at least I) tried to make adjustments for different drivers. I had several less experienced drivers tap their mirrors, and then wait until an appropriate straight to let me by. I also had several side-by-side's through turns with other experienced drivers. It worked just fine, and honestly I've seen MUCH worse passing etiquette and safety running in the top run-group at PCA.
Kudo's to Martin and Misty for putting on a well-run, driver oriented, SAFE event.
