Calabogie: tire goes pop [video]
#31
Calabogie is an AWESOME track and if you can, make your way there. It's well worth it.
#34
+1
That tire didn't JUST hit cord. It appears to have been run on cord for a while. Just a guess that the other side was the same or worse.
Really glad there was no damage or injury!
#35
#36
It was my first and only day @ Calabogie and I was having way too much fun and was totally occupied with staying on the track as much as possible. Yes, it's that good of a track. It's my favorite track! So I wasn't doing my normal checks on the car and it was totally my fault. Earlier in the day I did check my tires and they still looked good. I was on the track for approximately 45 minutes before the tire popped.
#37
[QUOTE=Rob in VA;6722986]My left rear tire popped while on track at Calabogie last week.
Luckily it wasn't an issue and nothing was damaged.
[url]http://www.vimeo.com/55
Hi Rob,
I was marshalling that day (inside 8). You say there was no warning signs. I think there were warning signs but that you missed them.
You had been getting better all day long. Then you spun once. You spun again a couple of laps later. You then got loose in corner 8. I called it in. Control suggested you were getting tired. I countered that I thought it was your tires that were getting tired. Next time around in corner 5 your tire blew.
I'm glad there was no damage, and hope to see you at Calabogie again,
Don
Hi Rob,
Don
#40
Hi Rob,
Don
Don
Besides getting squirrely, which was hella fun, the only other indication was the new vibration I started feeling going down the straight.
The first spin you mentioned was my first time ever spinning in the GT3 and I'm still pissed that it happened. I basically gave up on trying to save it. . The second spin wasn't a spin, I just got a bit sideways (way too many times).
I really look forward to getting back there and I'll be sure to thank you in person.
Thanks Don.
