How much negative camber........
were you able to get in the fronts of your racecar?
In my 911 my mechanic says I am maxed out at -2.3, while my buddies can get
-2.8.
What are you getting? and why such discrepancy?
Thanks......
-2.8.
Thanks......
change mechanic
There's a lot that goes into getting 2.8 degrees. Are you running the same strut tower brace as them? Same strut tower bushings/mounts? Pre-loading the brace the same? All other tweaks done?
Chris, I guess I don't have the same set up as my buddies.........
On my car the negative camber on the fronts is barely visible to the eye as opposed to theirs.......
Now that I think about it, they all use the same mechanic.....
My car was already bumped from stock E to prepared F.
Do you think the camber plates will bump me into G?
Not to mention ride height, making sure your control arms aren't bent, factory tolerances, etc, etc. Tons of things play into the amount of camber you can have.
Paolo, if you're already in prepared, you can run camber plates and have more negative camber than if you were running in class as an E car.
