Installing Wheel Studs Q
Not sure if this would be the place to post this question. I bought the stud Kit to replace the wheel bolts. I asked if I should use some locktight thinking the answer would be yes but then to recommend which kind. to my surprise I was told not to use it as it heats up and when hot it acts like a lube to allow the stud to work loose.
Looking for recommendations and experience with it/
also, Do you still use an air wrench with the stud kit or do you have to do by hand hereafter?
If the studs are seated and torqued into place properly, you should have no problem using a torque wrench on them, IMO. As for the locktite, I did not use it on the studs I put on my BMW M3. No problems whatsoever upon doing so. The key is putting them in place with a proper tightening.
C.
C.
I used high temp red locktite. The studs I got are just long enough to fit my BBS wheels, easily long enough for the others. If I put them in as far as I could, then they would not be long enough. How long are the studs you bought, and what wheels are you using?
I would use locktite...the directions that come with the studs we use recommend red locktite and torquing them into the hub at around 15 ft lbs IIRC.
Even heated, locktite does not act a lube. I've had to heat the studs red hot (i.e. much hotter than the hub gets from your brakes) in order to break down the locktite to remove some of the stuck studs in the past.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Loctite 272 is red high temp.
65mm and the stock 997-3 rims
GT3 player par excellence
i used red locktite, never had prob, i also use impact wrench on it.
however, i regretted doing it because the ease to put wheels back on was minimal and the look was not nice to me....
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I can't imagine NOT using locktite on something as important as a wheel stud.
If you think wheel bolts are "easy", you obviously don't change wheels tires enough. When pulling tires to nut/bolt the suspension 4-6 times per day, 12+ times per weekend, you quickly realize that wheel bolts are a huge pain.
That doesn't even get into changing a wheel in the pits...
Unfortunately, few of us race in classes or at a level where center locks are allowed. They are certainly an easier solution. For a street car, sure, I see no reason to use studs, but I assumed we were talking about track/race cars here in this forum.
Herr Unmöglich
HA! Proof the 944 IS a performance car!
Twas delivered from the factory with studs
Though it did use aluminum lugnuts... at least steel nuts are cheap to retrofit.
We were, I do about 15 track events per year, and because I rotate the tires on the rims I find myself swapping tires side to side at the track. Using that little guide bar is a pain in of itself. With my bad back trying to balance the tire on the hub is truly in fact for me a "pain" . I will be going with the red locktight on the install. Did not make sense not to but hey what better place to smoke out a myth then on rennlist.
