Racers with Cool "Suits": Questions for you.
I am in the process of developing an alternative pump system that can be used with either "Cool Shirt" or " F.A.S.T" shirts. But I need some input if this is a viable product.
My product would do/perform the following:
1. Eliminate leaks
2. Last longer (cooling time)
3. Be less cumbersome
4. Be lighter weight
5. Easier to use / install
Given these factors - how much interest would there be in a system such as this? I cannot go into the details of the system as of yet (patents are being prepared.) But I can tell you this - the cooling efficiency would be dramatically increased with substantial weight savings versus traditional ice/water based cooling systems.
Are there any other issues that plague these systems on track? Pricing would be similar to existing systems but offer substantial benefits.
Thoughts? Any input would be GREATLY appreciated.
C.
1. Eliminate leaks
C.
As long as the shirt fabric was fire resistant (Nomex, CarbonX, etc.), it might have some value. One issue I have seen is the imcompatibility between CoolShirt & FAST hose ends. They usd to be the same, but one of them changed a few years back for competitive reasons, and now many of us have to haul around adapters when we drive other peoples' cars. Also, make sure your product can also send cool air to helmets equipped for it. My sense is that a new technology rig with some sort of electric-driven heat exchanger (like a mini A/C) would in theory be a lot better and consistent thru a long race than one using ice & water...if that's what you are considering.
Professional Racing and Driving Coach
Because the tubing is of a plastic/vinyl material, the Nomex idea is possible, but not likely. My intention is to use existing shirts - as both systems have done really well in designing them but lack the "finish" with the pump system.
Your "idea" is close. My concept uses simple but more efficient principles to achieve better cooling efficiency.
C.
Possibly. I am negotiating with the other half on visiting friends in St. Louis that weekend or not. Prefer - not.
Side note - the toy should be done this week. It gets aligned today.
C.
You can already buy the existing shirts in Nomex or Carbon-X, so no need to reinvent the wheel there.
I don't have any leaking issues with my Cool Shirt system but would be interested in a unit that allows the same amount of temp reduction (or better) that also lasts for at least a 90 minute enduro in 95+ degree weather. Having it cost-effective would be a real plus, obviously.
I have found ways to cure all those issues and I like the additional weight to be used legally for ballast. I am sure others will find a simpler system very advantageous though.
1. Eliminate leaks
C.
1. Eliminate leaks
C.
The problem I have with my cool system is that the fabric of the shirt is so heavy that it makes wearing it worse than nothing at all, when the water isn't flowing. I hate the thing and never wear it anymore.
Not only would I buy a better system, I'm now going to e-bay mine before it becomes obsolete!
