HELP, emerg. cut-off dilemma
I am at the Glen race and while going through tech discovered that the emergency cut-off does not shut off the car's running engine. It appears the powers that be will not allow me to run without a properly functioning cut-off.
The cut-off switch that was previously installed in the car cut the engine right away so, although I didn't know how it was exactly wired, I didn't worry about it. The old switch had started to fail so I had it changed as part of the prep for the Glen race. The shop that did the installation wired the ground through the cut-off and not the power. So when the cut-off is engaged the battery loses ground and supplies no power. But the engine still runs because the alternator is grounded independently just by the way it is mounted. After some discussion with the shop owner he suggested I use the secondary terminals on the cut-off switch to loop the coil power through the cutoff. I did this and it does effectively kill the engine right away.
I now have a cut-off switch that cuts the battery ground on the main terminals and on the small secondary terminal is cutting off power to the coil. It works but does anyone see any problems with this setup? The power to the coil will always be running through the switch as will the battery ground.
You should get a 6-pole switch, so you save your alternator during the moments your engine is spinning down after the switch is thrown, as the power output needs somewhere to go. The 6-pole switch gives the alternator a resistor to shoot its last bits of electricity through...
And most clubs require the positive to be cut off... by just cutting off the ground, if your car gets crunched, it may find a new ground (anywhere on the chassis).
Oh, I fully agree, I just didn't turn my mind to it how the cut-off was wired when I picked up the car and drove off to the Glen.
Here is a write-up I did on installing a kill switch in a 964... it should give you the idea! It's the only way to go, in my opinion. Especially when my club does "spot checks" of the kill switch after races in the impound - the frequent testing of the switch will surely roast the alternator over time!
Here's the link:
https://rennlist.com/forums/964-foru...right-way.html
Here's the link:
OK, the 6-pole connector is what I have, just that the ground is routed through the main terminals and not the main battery power, that should be easy enough to change, more or less. The coil is also routed through #2 secondary terminals. The #1 secondary terminals have nothing.
How does the suggested install actually save the alternator? Where is the last bit of power routed? What goest to the #1 terminals?
Here is another writeup I did for the 944Spec guys
http://944spec.org/944SPEC/content/view/77/25
you should be using all the terminals on the switch.
Herr Unmöglich
I just triple checked my wiring on a 944 with a 6 pole.
Main poles
1) Red from battery
2) Wiring harness and main power
Secondary poles
1&2) Coil
3) Loopback to Main Pole #2
4) Runs to a resistor as described by garret. This allows the alternator to bleed current as he described. The other side of the resistor goes to ground.
Main poles
1) Red from battery
Secondary poles
1&2) Coil
Schwank,
OK on main poles and 1 & 2 secondary on the coil.
The 3) loopback to main pole #2, is that just back to the pole terminal? because that seems a little different than the wiring diagram.
You need a new shop.
Here is the source for the right switch
http://www.pegasusautoracing.com/pro...asp?RecID=1464
And how to wire it
And how to wire it
Link to wire it:
http://www.pegasusautoracing.com/pdf...structions.pdf
And how to wire it
And how to wire it
