Brake Fluid Stats
Basic Site Sponsor
Basic Site Sponsor
I feel a little differently on the subject. Sure the SRF is probably the best, but do you really need it for our cars? I run the Pentosin Racing fluid, and the DBP is 10C less than SRF. If you are changing the fluid properly, the WBP should never be a factor. Plus if your car REALLY needs such a high temp fluid, you have other issues in your braking system that you should address, i.e better cooling, different pads etc. One thing I can tell you is that the stock seals are not meant for such high temps on a constant basis. I have experienced brake O-ring failure in one weekend (they started out new) due to high brake temps, and the fluid never boiled. This happened more than once.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Sure SRF is the best for wet boiling temp but it isn't the best for dry and in a DE/Race car there is NO reason you should have fluid that is old enough to be concerned about the wet boiling temp. You should be bleeding your brakes every weekend and doing a full flush at least once a year. If you do that maintnence you'll never have to worry about the wet boiling point (the major selling point of SRF)
The only application I personally think that SRF would be worthwhile is the tow vehicle which gets much less brake fluid attention. In a racecar there is no gain compared to other brake fluids that are much cheaper.
I look at performance of a brake fluid as how often I have to bleed (after every session, after every day, after a weekend). Motul = every 1-2 sessions; Castrol = every 1-2 days.
My personal theory is that once you put fluid in your system you're dealing with the wet boiling point from that point on due to contaminants (no matter how clean you think your lines are).
Basic Site Sponsor
Basic Site Sponsor
Know all about that Jay. I ran a Carrera with stock brakes for 15 years. I'm just saying that a few degrees should not be the deciding factor between boiling your fluid or not, and if your temps are up that high, you need to find a way to address that. Improved cooling, pads that generate less temperature or that send less heat back to the caliper are better alternatives (IMHO) than maxing out on brake fluid boiling point.
Know all about that Jay. I ran a Carrera with stock brakes for 15 years. I'm just saying that a few degrees should not make much of a difference and if your temps are up that high, you need to find a way to address that. Improved cooling, pads that generate less temperature or that send less heat back to the caliper are better alternatives (IMHO) than maxing out on brake fluid boiling point.
I don't disagree that it may be overkill for many cars.
Having spent a ****-ton of time on the brakes in my 911SC over the last 10 years, I'm quite positive there is nothing left that can be done to improve cooling for the stock calipers and rotors beyond what I have done for my D class car (blockoff plates, ducts/hose directly to the front bumper, titanium backing plates, etc etc.). I can tell you that everyone in my car/class has the same issues.
Maybe if we could add electric fans in the lines... I looked into that at one time.
We do what we can to deal with the stock brakes - drive around the brake limitations, keep the brake system in top condition, bleed frequently, use the best fluid available and keep a supply of caliper rebuild kits on hand.
Cheers,
Jeff
If this were true then a fluid like Motul RBF 600 would peform just as well as Castrol SRF. I have used them both extensively and I can tell you that it's not even close.
All I know is that since I switched to SRF, I bleed less and my brakes feel better (was using Motul before). Win-win for me: less work, better brakes, high confidence. I was a skeptic once about "liquid gold" (what the SRF brand manager calls it), too.
But this is a religious argument. We might as well start talking motor oils...
