Motive Power Bleeder - procedure
#46
I was thinking about this today. I have the Motive pro which comes with a quick disconnect. You could by a pressure regulator for in line with the air hose, if our compressor does not have one. You sometimes need a pressure regulator with some air tools anyway, and as you said set it to about 10psi and Wham, you got a high power power bleeder. I like it.
I am for sure the dry method. What is funny is that when I bought mine I never read the instructions "shocker" and did not know that they recommended putting the fluid in the bottle, just made more sense to use it as a pressure device and limit the fluid to the brake system.
After reading all the posts I do now wonder if we are pushing old fluid out of the ABS. I will have to think about that.
