Traqmate Group Buy
#61
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The AIM sensors and patch cables are cheaper.
I'm not sure if it's changed but when I priced out an IQ3 with oil pressure, oil and water temp, TPS, brake pressure, steering angle and the associated plugs and such the difference in price between the IQ3 and the AIM MXL Pista was on the order of a 2-300 dollars with the AIM being slightly more expensive.
If you switch out the MXL Pista for the EVO4 with Mychron dash the prices are nearly identical.
As for the spreadsheet comparing prices and capability it's a bit skewed towards the IQ3. The GPS module is now 399, a number of the features where it says included with the IQ3 and 'requires wheel speed or GPS" for the MXL should actually read included as the wheel speed sensor is included. External sensor inputs are greater than 10 when used with the channel expanders.
As a side note in the next few months the SRF I just picked up will be a test mule in that it will have a Traqmate, AIM EVO4 and Racepak IQ3 systems all running simultaneously and used as a training tool with some local programs. It will be interesting to see the stuff back to back to back. Then my head will explode wtih all the data.
#63
Its been a long day, but good news is that Rennlist sponsor OG Racing is fully supporting Dan's group buy.
Here are the details, based on a minimum of 6 units combined [G2X + IQ3]
Racepak G2X package: $810 including shipping to the lower 48 states
![](http://www.racepak.com/images/G2X_Red.jpg)
Channels:
V-Net: 12, Internal: 4
Sample Rates:
V-Net: up to 100 per second
Memory:
SD memory card
Recording time depends on number of channels monitored and sample rates
Internal Sensors:
Battery Voltage
Longitudinal g-meter (acceleration and deceleration)
Lateral g-meter (side-to-side motion)
GPS
Dimensions:
5.6” (L) 4.00” (W) 1.5” (H)
G2X Display Overview
![](http://www.racepak.com/images/dash_description.jpg)
Simple, 2 Button Programming Functions
Setup programming mode
Brightness
Return to factory settings
Tach signal
RPM source
Progressive shift light steps
Shift light RPM level for 6 gears
Speed source
Gear Indicator Ratios
GMT settings
MPH or KPH
Select on-track left and right display
In-car programming
Set Gear ratios
Set Start / Finish with a single button
Extra Bright LED’s insures information is daytime visible even in open cockpits
Forward / Rewind of laptime information
Displays Lap Number and Lap Time each time Start / Finish is passed
Displays Predictive Lap Time during the lap - time difference between this lap and the reference lap updated continuously through each lap.
Automatically returns to Lap Number and Lap Time when vehicle stops
Automatically resets Lap Number and Lap Time when vehicle returns to track
Left and Right button toggle allows anytime viewing of data channels
User programmed Left and Right display allows user to “park” on any of the following 2 channels:
Engine RPM
Speed
Lap Time
Lap Number
Lap Difference
Accel G
Lateral G
Battery Voltage
Any 3 user defined external sensors
Racepak IQ3 Logger Dash package: $1185 including shipping to the lower 48 states
![](http://www.racepak.com/images/iq3dash.jpg)
· 32 Channels
· Internally Mounted GPS
· Internal 3 Axis G Meter
· 512MB microSD Memory Card
· Programmable Shift Lights
· Programmable Warning Lights With On Screen Warning
· 24 Programmable Sensor Inputs On 4 Pages
· Programmable 5 Character Channel Name
· Gear Indicator
· Predictive Lap Time
· Power/Ground/Engine RPM/
· External Programming Button Harness [see note below]
· Speed, Lap Time, Lap # and Predictive Lap time from GPS
· Metric / Imperial Configurable
Datalink II data analysis software [both models]
· Track Mapping, Segment Times, Lap comparison reports
· Extensive Data graphing and Reports
· Video integration allows video files to be loaded for each data session.
· Video files can be synchronized with the data, and viewed within Datalink II
· Fully integrated with TrackVision to produce high quality video with data overlay. For a quick look at how this works, click HERE
· There's a short sample of what the video looks like HERE
· The TrackVision software is sold separately - $195 from OG Racing.
Other things you might want or need
RPM Pickup: Porsche DME cars can pick up RPM from DME Pin 6, but RPM on both earlier points/CDI ignition cars and later coil-on-plug cars is much easier using Racepak's GMR module which is around $42 from OG Racing. There is a G2X version and an IQ3 version [the connectors are different].
IQ3 Programming Buttons
In-car programming and control of both units is via two programming buttons. The G2X has these buttons on the display itself, but for the IQ3 the buttons need to be mounted remote from the display. The two switches are not provided with the IQ3. There are two options:
- Racepak provides a program button set with a harness. I don't know the correct item name or the price, but I'll find out and post on this thread soon.
- You can use any momentary on switch to do this. Please don't use Radio Shack rubbish, but any decent switched will do. The best place to mount them is on the console behind the shifter, where you can reach them with your harnesses cinched up.
Additional Sensors - the Racepak VNet world
Racepak's VNet sensor system is basically a CAN bus that uses a single cable to connect all sensors to the logger. All the nice thought-bulkhead fittings and angle connectors you could imagine are available. The sensors themselves are 'smart' devices containign a microprocessor. When you plug new VNet sensor into your system, it registers itself with the logger and appears in the logged data as what it is eg. "Temperature 0-300F" or "Throttle Position" or "Brake Pressure 0-1500psi" etc. Very nice! The VNet sensors are prices competitively with sensors from other higher-end logger vendors like Pi Research, Stack, AiM and MoTeC.
For us lower budget racers, Racepak offers their Universal Sensor Module [USM] which adds four sensor channels, each of which can be configured for analog or digital signals [pic below]. Price is $179 from OG Racing. This turns out to be a pretty neat solution for most of us. You can get throttle position direct from the TPS on any car that has a true TPS rather than the switch-only TPS on the Carreras, 964s. You can pick up you brake switch for a brake on-off channel, or add any 0-5V brake pressure sensor. You can use a cheap GM temperature sensor for oil temp [the software includes calibration curves for the GM sensors] and any 0-5V pressure sensors.
You can also connect a second USM for four more channels, or use any VNet sensor, or do both. The system is very flexible.
What else?
The one thing that becomes really obvious once you see the Racepak gear is the build quality. The enclosures are beautifully made, they use high quality connectors, and everything just goes together and works. Take a look at the USM pic below. Each of the sensor wire ports has a water resistant seal, and the unit has an full o-ring seal on the top of the box. Niice!
Which one is for me?
It really risky to generalize, but here goes........
If you are doing DE in a street car, the G2X is probably the best choice because the logger can be velcro'ed to the floor or mounted basically anywhere that is level. The display can also be mounted in a way that makes it easily removable for street use. It can be anywhere on you dashboard that you can see and reach while driving [you need to reach the buttons to set Start/Finish position on track or change the displayed channels].
The IQ3 is a true display dashboard that really needs to be mounted directly in your eye line. The unit must be parallel to the car's center line [for the G sensors to work correctly]. Mounting on the steering column makes most sense. This is perfect for a dedicated track/race car, but maybe not for a dual purpose car. Its not something you would want to install/remove for a track day [although you could, of course].
Sorry this turned out so long, but hope this info helps listers interested in the group buy. Thanks again to Racepak and OG Racing for their generous support of this group buy!
Channels:
Sample Rates:
Memory:
SD memory card
Internal Sensors:
Battery Voltage
GPS
Dimensions:
Brightness
Tach signal
RPM source
Speed source
GMT settings
MPH or KPH
In-car programming
Set Gear ratios
Engine RPM
Speed
Lap Time
Lap Number
Lap Difference
Accel G
Lateral G
Battery Voltage
· 32 Channels
· Gear Indicator
What else?
#66
as someone who just purchased data aq, don't focus on the hardware so much. Go use the software, most have free downloads of their software and you can find data almost everywhere. Spend time with the software, using it and see if its easy and you can understand it.
The racepak software was awful, not intuitive at all. AIM was easier to use, traqmate is like using the mac of data aq, very easy to pick up and go.
Also think about what people have around you, and the benefit of being able to share data. I chose the traqmate in the end, its super easy to use, easy to swap between cars, and the guy that coaches/works with me is very familiar with it.
#67
Dan:
I left my info with Steve at OG Racing. Looks like we need 5 more (either IQ3 or G2x) to make the group buy work. So let's start making some calls guys.
#68
I have the following installed here, and use all of them on a regular basis:
- MoTeC i2Pro
- AiM Race Studio
- Racepak Datalink II
- Race Tech RT Analysis
- Stack DataPro
- Pi V6
- Racelogic Tools
- Traqmate Traqview
- ETB ERace
- Plus a few others
You need to spend a little time getting to know the more capable packages. The less capable packages tend to be simpler to learn. That's a sweeping generalization, but its pretty much the reality.
#73
Hi
Buy is still open, The kit includes everything including the head unit to see your times on the fly etc etc. Price is $850 shipped. Just send me a IM if you are interested and I will send you the details. (I actually went a deifferent route but the deal is still in place)
