Any photo experts who could explain this
Old 04-05-2009, 11:05 AM
MLIN
MLIN's Avatar
obviously the car is haunted. Tell your friend to get rid of it.
Old 04-05-2009, 11:17 AM
pmgoodwin
pmgoodwin's Avatar
Originally Posted by analogmike
No, it's due to the way the iphone scans from top to bottom as described above.
That would explain it. The curve in the upper spoke as it rotates forward for each subsequent scan down and the bottom spoke rotating back for each scan down.
Then it was just having the wheel rotating at the right speed and starting in the right place.
Old 04-05-2009, 11:42 AM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Put your hand on a flatbed scanner sideways and when it starts, slide your hand away from the scan bar slowly. You will have LONG fingers.
I hear chicks dig long fingers.
sorry. I'm grumpy from waking up for the "F1" race.
Old 04-05-2009, 09:51 PM
sjfehr
sjfehr's Avatar
Echoing an artifact of the raster scan of the camera. I have the same problems when I use the camera on my old Treo. Here's a photo I took in Japan that didn't turn out as well as I'd have hoped:
Old 04-05-2009, 10:55 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Old 04-05-2009, 10:57 PM
mglobe
The Penguin King
mglobe's Avatar
Originally Posted by pmgoodwin
Okay, this is a little OT but it was taken while driving Porsches at high speed
on a PCA drive.
I had my iPhone out trying to take a pict of a a friend as I passed him. I ended
up getting his front wheel instead. I was about to delete it when I noticed
something strange about the wheel.
The photo below is not photoshoped or doctored in anyway. Can anyone
explain what caused the effect.
Paul
I think it has to do with torque. Or maybe horsepower....
Old 04-05-2009, 11:27 PM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Thought it was nitrogen in the tires.
Old 04-06-2009, 12:32 AM
pmgoodwin
pmgoodwin's Avatar
There's always one...
Old 04-06-2009, 01:24 AM
fuenfer
fuenfer's Avatar
It has more to do with torque, because torque is superior to horsepower.
Old 04-06-2009, 08:05 AM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Massive torque can twist the metal in the spokes to turn straight spoked wheels into twists.
Old 04-06-2009, 09:07 AM
Willard Bridgham 3
Willard Bridgham 3's Avatar
Ahhh.....that would explain it......it's a front-wheel drive car.
Old 04-06-2009, 10:48 AM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
I've been waiting for some time for someone to build a rear-engined FWD car.
Old 04-07-2009, 01:50 AM
ervtx
ervtx's Avatar
The spokes and the bolt holes are all distorted but the bade on the cender cap is normal.
The wheel well and tire is distorted as well. And did you notice that warning in your side view mirror? You clearly have a twisted, distorted view of things. Better slow the flagnog down!
Old 04-07-2009, 09:42 AM
Chaos
Chaos's Avatar
Doppler shift passing thru a burst vortex
Old 04-07-2009, 11:05 AM
John H
John H's Avatar
LSD
Quick Reply: Any photo experts who could explain this
