Corbeau TRS seats/brackets in a 968/944
I'm about to order Corbeau TRS seats and brackets for my 968. Since I'm on the tall side (6' 2") I was wondering if anyone that has the Corbeau brackets can give me an idea of how much height thay add (if any) to the seat over the stock rails. In the 944/968, the factory rails are pretty much right on the floorpan, on just a slight riser (about 1" max)
The same Corbeau bracket part number is spec'd for the 911 as well. If anyone has them, a picture would be greatly appreciated.
Thanks!
Thanks!
John,
I would suggest getting the seat bases shaved an inch. The lowest sitting reclinable Corbeau seat is actually the A4 and you can also shave about an inch off these seats as well. If you are using a 5- or 6-point harness, you can also get the sub-slots installed in the seats.
We had a customer in Ohio do TRS wides and he needed to do fabrication to get the seats installed in his 968 (since the seats were wider) and to sit as low as possible.
Check with your Corbeau dealer about shaving the bases & subslots or feel free to give us a call.
Linda - Toll free: 866-505-2739
ApexPerformance.net
Premier Racing Outfitters
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
