Sunroof Hold-Down In 944
03-21-2009, 01:51 PM
What is the best way to fasten the sunroof down? I have removed the sunroof motor. The car is a track ONLY 944T. Should I fashion tabs or brackets? Use bolts or rivets? Photos of what you have done will really help. Thanks
Steve
03-21-2009, 06:03 PM
fab some plates and bolt it from underneath. You can use the stock latch locations for the bolting into the sunroof.
03-21-2009, 06:19 PM
Thanks M758. What about the outside? Nut and bigger washer?
03-21-2009, 06:37 PM
I just used latches from a manual sunroof. Quick and easy to remove if necessary.
03-21-2009, 06:51 PM
you all have me worried now,
I removed the sunroof motor and assumed it would have no issue as the roof panel still has the original clips attached to it. Is this safe?
03-21-2009, 08:01 PM
I used machine screws. Held it down tight. :P
Seriously, I did.
Now I'm going fiberglass roof though. A bit more class.
03-21-2009, 11:41 PM
Herr UnmöglichRennlist Member
I did something like Joe and fabbed 2 plates. I use manual sunroof latches in the rear, with the front screwed in.
03-23-2009, 10:32 AM
Quote:
Originally Posted by
carreracoupe997
Nothing. That is the beauty of useing the stock locations. I just bolted in to the existing holes in the sunroof.
DanR
Not in the back.
03-23-2009, 10:40 AM
Here's what my shop did. (Note the plate.) There are also machined plates bolted in where the stock latches go. The attachments work perfectly.
