Kirkey seat restraint kits?
I'm currently running a Kirkey Deluxe road race seat w/ a seat back brace and a right side Simpson net. I was also using an Isaac head and neck.
Currently moving to a HANS due to PCA's change in rules about H&N requirements. So I'm also considering adding the containment pieces Kirkey is offering. They currently show two different setups. Anyone use either one? Any feed back? Thanks in advance.
Here is what is posted on their site:
http://www.kirkeyracing.com/index.ph...ode=Restraints
987 Kit - Head & Shoulder Restraint Kit
Our Head & Shoulder Restraint Kit allows you to reto fit your existing KIRKEY seat to take advantge of the added safety that a head and shoulder restraint system offers. These kits must be used complete in order to be effective; the head restaring cannot be used separately. The kits are made from .100" 5052 grade aluminum and padded with energy absorbing impact foam. All mounting hardware is included with the kit.
988 Kit - Tube Head & Shoulder Restraint Kit
Our Tube Head & Shoulder Restraint kit allows you to reto fit your existing KIRKEY seat to take advantge of the added safety that a head and shoulder restraint system offers. These kits must be used complete in order to be effective; the head restaring cannot be used separately. The kits are made from .100" 5052 grade aluminum and padded with energy absorbing impact foam. All mounting hardware is included with the kit..
I have a Butlerbuilt seat that is similar the Kirkey. I used a system that is similar to the 987 model with an Issac system, but when I bought mine years ago, that was about all that available. No complaints on visiblity or movement. I think either one will work.
Kirkey responded to my question and stated the Tube Head & Shoulder Restraint Kit was a bit stronger and most prefer it for better visibility
