NT01 review
Well, this past weekend, my first set of NT01's gave up the ghost. I ended up cording 3 of the 4 of them by Sunday afternoon. Having previously used & loved the RA1's, I was interested to see if NT01's were as close to RA1's as folks have said.
They were, and they weren't.
Obviously, full tread NT01's are not like shaved RA1's until they wear down some tread, but they weren't bad. And they did get a lot better when they wore down. In fact, they might be a tiny bit quicker worn down than shaved RA1's. But they are a lot more sensitive to pressures/temperatures than RA1's, and they seem to also prefer less negative camber, likely due to having stiffer sidewalls. I found via probe pyrometer that they preferred slightly higher cold pressures than the RA1's, but even a pound too much created a tire that went away a lot faster, unlike RA1's.
As for wear, I got approximately 30 very hard heat cycles from my set...so excellent value!
Professional Racing and Driving Coach
One thing I forgot to add: like RA1's, they work well on damp/drying tracks.
Basic Site Sponsor
Basic Site Sponsor
VR, I told you all about NT-01s last year.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
What pressures did you end up with hot that worked? There was a thread last year that discussed running these tires at very low pressures.
Basic Site Sponsor
Basic Site Sponsor
Tim, were you asking the purveyor of all automotive knowledge, or me?
IIRC we ran ours around 34~36 lbs depending on car (951 & 993) and tire size.
VR a timely post, as I have a set of NT-01's delivered this week. 245/40/18 and 315/30/18. Can you give me an idea as to what your car's wt and and what type of pressures u ran. Also if you don't mind sharing what type of temps were you pulling off of them. Thanks.
I know you did, grandpa...but I just got around to trying them this year! ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Frank & Tim, I really didn't pay attention to hot pressures, since I was using a pyrometer. I ended up with cold pressures of 25 front, 23 rear, on a car that with drover + fuel is about 3,100-3,200 pounds.
VR, do you have any experiance with Toyo R888's to compare to the NT01's?
Frank, I forgot to add that I was seeing (on dry track) around 180 to 185 degrees in the hottest sectors of the tires on a warm 80 degree day.
