Brake Rotor Recommendation
Old 03-07-2009, 07:18 AM
  #31
pantera43
pantera43's Avatar
Originally Posted by Porsche917K
For the 964, I like solid rotors from Vertex. I think you will see longer life over any drilled option. I would also recommend upgrading to the later rear caliper and using the PFC 97 on all four corners (same pad F and R) for the track.
Thanks for the recommendation and advise. I'm new and sort of tip toeing into the DE scene with my 964. If I find myself liking it and doing more events I will defintely do the rear caliper upgrade and PF 97 pads. I could be wrong but I fiqure as long as I have fresh fluid(Motul 600), new rotors(OEM Porsche) and pads(Porterfield R4) I should be ok as far as my brakes go?
Dan
Old 03-07-2009, 12:40 PM
  #32
Porsche917K
Porsche917K's Avatar
Yep! You'll be good for the occasional DE for sure. Have fun!
Quick Reply: Brake Rotor Recommendation
