bolts for Recaro Pole Positions side mounts?
I bought used Recaro Pole Positions. The bolts supplied to attach them to the side mounts are short dome-heads w/5mm hex hole. Black, no specs on them. I don't know if they are OE w/Recaro or something the previous owner stuck in there.
They seem pretty whimpy.
Any one know the specs on bolt size? Should I get hex-head and washers?
(8.8 or better hardness I assume).
Thanks.
Thanks.
Thanks.
Thanks.
![](http://forums.pelicanparts.com/uploads14/01_13_09_1231873702.jpg)
the others aren't so critical wrt to clearances so any M8-1.25 x20 grade 8.8 or better will do
![](http://forums.pelicanparts.com/uploads14/01_13_09_+0011231873729.jpg)
Shannon,
The hardware I received with the mounts for my old Pole Positions, and my new Profil XLs, included black, cap-head bolts (one set was 6mm drive, the other 8mm). The 8mm set were marked 8.8. The dome head (pan head) bolts are for mounting the rails/brackets to the chassis, as Bill pointed out.
Without seeing a pic., I would venture to say you should probably contact a reputable supplier and get some new hardware. Recaro supplies a hardware bag that has both sets of bolts and washers, and although I haven't tried to buy it separately, I would imagine it is readily available, and not expensive.
Regards,
Dave
Regards,
Dave
Shannon,
Regards,
Dave
Regards,
Dave
Do most people drill additional holes in the seats to secure them?
I can hardly stand the thought of those 4 small bolts determining if I live or die in a crash.
I was wondering about the number also. Seems crazy I'm using as many bolts of the hardest rating I can to secure the rails to the car. Then I have 4 tiny bolts holding the seats on.
5x M8s holding each sidemount to its rail. All 10.9
Basic Site Sponsor
Basic Site Sponsor
I like to use flange bolts, especially for the side mounting holes. It makes it easier to get a wrench down to re-tighten them vs Allen head bolts. And they do loosen over time.
![](http://www.bolts-nuts-washers.com/images/Flanged_Bolt.jpg)
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
