Height advantage: Recaro of Sparco sliders under a Recaro Profi SPG XL?
I ordered a new Recaro Profi SPG XL and some B-K sidemounts for my driver's seat. I've outgrown the Recaro Speed's I've got-tired of wedging my left leg on the dead pedal to hold me in place on the track-guess that's a good sign.
At any rate, I do like having the seat further back when driving on the street and a bit closer at the track, so I want a sliding mechanism. Since I want to keep it all as low as possible, does anyone know whether the Recaro of Sparco sliders have a height advantage over the other?
Thanks Mike. I can't see how one could possibly improve on 3/4" by much. Plus, with the Sparcos, I'd have to get a B-K handle to set the sliders at the proper width.
Thanks.
One more quick question: The Recaro sliders come with or without height adjustment. Is the height adjustment worthwhile, and does it do anything to flat height?
There is no height adjustment on the flat Recaro re 0.70.9NT sliders.
I have pretty much the same setup, 1984 Targa, Recaro SPG XL, BK, and Recaro sliders.
Right now the car is in the shop having a custom rollbar installed with door bars to stiffen the car.
But the passenger seat/parts are here if you want to see some pictures.
Phil
Phil
Ed,
I think you need the non-height adjustable sliders (0.70.9NT) for your car. Later cars have 16" spacing so you can bolt the sliders directly to the floor and to the seat brackets. The height adjustable sliders (0.70.9) have tabs on the ends that would not allow you to bolt the slider directly to the floor (the "NT" stands for "No Tab"). Early cars (pre-73) have 18" seat mount spacing so they require an adapter to move the mounting point inwards to match the spacing of the racing shell. Wedge Engineering makes an adapter for early cars that has tubes welded in parallel to the mounting base to which the height tabs bolt.
You aren't missing out on anything, since the height adjustment tab only allows the base setting and two higher settings and it sounds like you want to be as low as possible.
