Cross post: FS: GT3 Sway bar and links
12-01-2008 | 06:17 PM
12-01-2008 | 08:57 PM
Which droplinks do you have? Are they the ones with the collars on them?
12-01-2008 | 09:34 PM
Quote:
Originally Posted by
amondc
I'll post some pics. I'm not sure what collars you are referring to. If these are going on your brother's car, I'll saw halfway through one of the drop links.
[j/k of course]
Tom
PICS HERE
12-01-2008 | 09:57 PM
Ahh ok there is another mount that goes around the shock which makes for better angles on the boxster. I was not sure if you had those or not.
12-01-2008 | 10:00 PM
amondc
Roger. Does the collar fix the geometry due to the shorter drop link?
BTW, do you have an extra 18X10 et65 wheel lying around? I kinda need one.
-td
12-01-2008 | 10:04 PM
Yes, and I think we may have a set but not a single wheel. Might make you a good deal on a set. They are off C4S? If you think that may work.
12-01-2008 | 10:07 PM
himself
-td
Yes, Tarett has a new shock collar mount and longer links to address the geometry issue. Check them out on my car, it is back at BWP....
I am (or possibly John) calling Cory Jump tomorrow, will check to see what he has.
12-01-2008 | 11:37 PM
The photos don't appear to be of the longer 996 links as pictured with the shock collars below:
12-02-2008 | 12:00 AM
jrgordonsenior
The photos don't appear to be of the longer 996 links as pictured with the shock collars ...
Correct. I didn't have the collars.
-td
12-02-2008 | 12:10 AM
amondc
I'm only short one rear
And I think the C4S offsets won't make it on my car. I'll keep digging. Thanks for the offer though!
bsr_257
Roger thanks. I think John has my number if something comes up.
Much appreciated,
-td
