Track Rims for a 996 NB
Negative Camber for 996
GT 3 (Street) lower control arms will give you -2.5 degrees of front camber.
Be real careful with front to rear tire combinations. Rolling radius delta, front to rear is critical if you want the ABS to work. I believe a 3% delta is about as much as the system can tolerate...at least this is true on a 993...maybe not the case with a 996.
You can get the OEM GT3 monoballs for $300 for the pair which is why I went that route.
These monoballs are like adjustable camber plates? what place sells these?
Also on the boxster rears, are all years for these rims good or are there specific years with a better offset?
here's a picture of the OEM plate for reference.
HOWEVER!!!*** while I can tell you that you can re-use the stock upper spring bearing from your 996 to integrate with the GT3 mounts, I can't guarantee you won't get a ride height change when you use them. I already had coilovers on my car when I installed the plates. If I remember correctly the height was pretty close but not exactly the same as stock. (within 5mm).
Andy
for what it's worth, I ran GT3 Wheels 8" ET 55 (or 8.5") with 15mm spacer with 245s and 11" ET 65 with 315s on my NB 996 track car. Slight rub on front when at lock to lock but great on the track (and driving too and from).
I run 17 x 8.5 (boxster rears) on the front of my car for the track.
The issue you'll run across is the widest factory 17' wheel available is 9'. Patrick E (I think??) has run the 8.5 F / & 9/ R setup and like it. I wanted a wider wheel at the rear so I'm running a stock 18 x 10 rear on my car.
running 245/285 or 255/295 tire combo and the car is very well balanced. Lost of people give me funny looks for running different diameter wheels front and back but it's cheap and effective. You obviously loose some feel in the front though with the taller sidewall.
Andy
Andy
i sometimes run my fikse 17/9x10.5 with 245/315. the rears fit and work well believe it or not. i would like a fatter tire up front though... like a 265.
Karlooz,
I've been running a 275 R6 up front this past year. Worked great. However, I think that a 265 or 255 with the right aspect ratio would be "enough"
My track setup has been F275 F 315. Very soft front GT3 bar and very stiff rear GT3 bar. Actually, I stiffen the rear bar until I start to get excessive wheelspin in corners and then back it off a notch. Keep the car right on balance.
Karlooz,
is there a lot of roll with those wide meats on narrow rims?
i'll try out 275/315 next time. good thing kumho v710s come in that size with 17" rims. no such luck with 18" rims though. i can only get 245/305x18 and the next bigger pairing would be 285/305... the 315 is way too tall.
Yes they are a little fat. I plan to downsize the front this year to a 255 or 265. I really try to keep the OD very much in line between the front and rear.
Here is what they look like on 17s.
hey paul,
Karlooz,
What dampers are you using?
Jim,
Running a 04 GT3 takeoff susp. Shocks/springs, bars, monoball mounts, etc.
At first I left the rear bar in the stock GT3 setting and progressively softened the front bar to eliminate mid corner push. Then made a few more minor adjustments on the rear bar (stiffer) to dial in just enough in rotation before apex. BTW: when I move the bars I move one hole on one side at a time.
Also, I do need to be careful not to over turn the front wheel into a corner before I am fully committed on the gas before apex otherwise I do get loose. IE the front really does go wherever I point it.
I have always preferred a loose and fast car. My 2 cents.
