VDO Temp Sensor data needed
Old Oct 22, 2008 | 05:51 PM
Mike O's Avatar
Mike O
Default VDO Temp Sensor data needed
I would like to use a VDO sensor as an input to a TraqMate DAS. To do that I need the temp vs resistance curve or data. I did measure the resistance at 85F to be 17K ohms and at 205F around 950. That is clearly not in the linear range.
So does anyone here have that info or know where to get it??
BTW, these are the markings on the sensor: VDO I CZECH Republic I 10.07 I 130 C Max I 805/25/1 I 964.524.110.00
This sensor is used to provide oil temp to the 968 DME. No gauge, it goes to the DME only.
