Need source for slotted rotors
I have a 2002 996TT with Big Yellows, 6 piston front calipers and 350mm discs at all corners. My drilled rotors are forming small cracks so I need to replace the fronts with slotted rotors. Where's the best place to buy them, and at what price point?
The drilled rotors do crack. I've been using Farnbacher's solid / slotted rotors on my GT3. Their support is great. Their rotors are a drop in replacement fit for the OEM rotors. Check and see if they have one for your car.
203-798-2929 - ask for Robin
dan
dan
Steve -- Is that the porsche motorsports version or yours?
Larry -- I believe the crack protocal was no crack made it to the outside surface and no two holes connected by crack (but I'd confirm for sure).
Word has it Partsheaven now has Solid Slotted Non-Drilled Rotors front and rear for 996 c2 C4S and Turbo, Boxster S, Cayman S, 800-767-7250 ask for Al, Jeff or Spencer
Chris Whaley has been posting his rotors for sale on Rennlist. They are made by Sebro and I bought a set front and rear. Think his company is LC Motorsports. Will see how they work at Road Atlanta. First time I have been able to find rear slotted for my 996. Search "Whaley"
Steve
Believe it or not, I have been using a set of ATE slotted rotors on the front with Pagid yellow for 17 track days (agressive use of brakes as I have no HP). I'm on my third set of Pagids with little wear on the disks. Bought them based on deminsions and they were relatively cheap compared to the alternatives. These are on a track dedicated Cayman.
Former Vendor
We carry Sebro Slotted Sport rotors that fit the Boxster,Cayman, 996,997 C2,C4 models front & Rear. Check out our post https://rennlist.com/forums/parts-ma...-and-rear.html.
If you need rotors we have a VERY large inventory of each fitment in stock. Give me a call for specials on orders that include all 4 corners.
Cheers,
Chris
Cheers,
Chris
