DIY Footwork Camera Mount (with video)
I couldn't find a camera mount that would work for video taping footwork. I tried a bunch of different set-ups, and nothing worked with my cameras. I could have ordered a bullet cam and routed the wiring under the seat, but I already have 2 cameras and don't want to explain to the wife why I need another one.
So I went down to Home Depot today and walked the store for an hour or so to brainstorm ideas for a DIY camera mount. As it turns out, I found a PERFECT mount - for $2.79. It is a 3/8" grounding clamp found in the electical department. It looks like this:
![Name: DSC03585.JPG
Size: 64.1 KB](https://rennlist.com/forums/attachments/racing-and-drivers-education-forum/304260d1221431270-diy-footwork-camera-mount-with-video-dsc03585.jpg)
![Name: DSC03586.JPG
Size: 64.1 KB](https://rennlist.com/forums/attachments/racing-and-drivers-education-forum/304261d1221431292-diy-footwork-camera-mount-with-video-dsc03586.jpg)
As it turns out the screws/threads used on this clamp are EXACTLY the same size as the standard camera mounting hole. How convenient. [It actually came with screws that had a head for a slotted screwdriver, but I switched over to some hex head ones I had lying around.] Pictures of the assembled mount:
![Name: DSC03589.JPG
Size: 63.5 KB](https://rennlist.com/forums/attachments/racing-and-drivers-education-forum/304262d1221431333-diy-footwork-camera-mount-with-video-dsc03589.jpg)
No extra work needed - the camera simply screws onto the exposed bolt. I did add a round disc that I had from an old camera mount - but you could use a hex nut instead. This does 2 things: it adds a little stability to the camera and allows you to get the camera pointed in the right direction and then "lock" it down from underneath the camera.
I have Cobra Imola racing seats with standard pull up bars to adjust the seat. I simply added some racer's tape to the seat adjuster (pull-up) bar, and mounted the clamp directly to it. I positioned it so the camera is directly in the middle of the bar. Set up this way, the camera is unobtrusive and does not interfere with driving.
![Name: DSC03570.JPG
Size: 78.7 KB](https://rennlist.com/forums/attachments/racing-and-drivers-education-forum/304263d1221431350-diy-footwork-camera-mount-with-video-dsc03570.jpg)
![Name: DSC03574.JPG
Size: 81.2 KB](https://rennlist.com/forums/attachments/racing-and-drivers-education-forum/304264d1221431358-diy-footwork-camera-mount-with-video-dsc03574.jpg)
Link to video (also embedded below)
[EDIT: this video is me driving around my neighborhood pushing pedals for the test video - trying to figure out if the camera is positioned correctly to catch foot movement. The footwork is just illustrative and was not intended to evaluate performance, but to illustrate/verify that the contraption would actually work on the track.]
