Aiptek users: what is needed for race car use
About to pull the trigger on a Aiptek A-HD+ (should I get a different one?)
I read lots of posts about the Frankencharger, but couldn't find the actual posts on the specifics about how to make it.
Is there anything else I should get? Does it come with a remote? Other mods that need to be performed?
Links to specific posts would be helpful.
Thanks.
-Scott
Thanks.
-Scott
The Penguin King
Here is the Frankencharger post.
https://rennlist.com/forums/showpost...4&postcount=52
Above and beyond that, it's a good idea to shim the battery so that it makes constant and solid contact with the power pick-ups. The other item that's probably worth doing, is to buy one of the inexpensive magnetic wide angle lenses. There is a post listing some options on that within the thread you referenced.
I have a complete kit for sale. I've only used it couple of times. I have the remote, camera, charger, extra batteries (remote and camera). PM me if you're interested.
I upgraded to the Chase Cam.
I ordered my chasecam right before I went to Road America. I didn't take the time to read the instructions thinking that it's not that complicated. Well.... It took me a few days before I was able to get any recording. I bought the unit with Gforce and the supercaps. I expected that the camera to turn on once I put the car in motion. Well it didn't. Once I figured out how to record, my recording started to loop and record over itself. I figured how to change it but I lost some good footage. My other issue was the tube camera had a label showing "top". Whoever labeled it must have been drunk.
I don't like the fact that you have to load a special video player to look at the files. I need to figure out how to convert the files so I can edit the videos.
Other than that it's a great system.
Herr Unmöglich
Frankly all I have is the A-HD+ and the camera mount in the car. I run it on the battery and with no remote. Though I do intend to order the remote, just have not yet. I just hit record (or have my pit guy do it) sitting on pre-grid, and then I tighten down the belts.
So far it has worked pretty well like that.
It gives you several different options for conversion and is quick and can do a bunch of files at once.
