Oh No, not tire pressures again (DE; 997TT).
Moderator
Keep in mind I had my 997S for 1.5 years on the track and PSM NEVER kicked on (I never turned it off). It let me go 20 degrees sideways at the crest of the Esses at Watkisn Glen - I corrected and continued on. Point being the PSM system in the 997 product line is actually very good at not getting in the way of driving.
If an instructor came into my car and told me to turn off PSM and Sport on, I'd ask him to reconsider and if he insisted, I'd ask him nicely that it isn't going to work and that you'd like another instructor. It's your car and you have to be 100% comfortable in it and with the individual. If his style of instruction is "his way or the highway" regardless of your comfort level, then he shouldn't be instructing.
PS2 hot temps on the track should absolutely max at 41 and the more stagger you feed in (ie: less pressure front) the more understeer you will have remaining (depending on alignment, might not be a bad thing for added safety valve). In both my 997S and GT3 with PS2s I think I would generate 12 psi front left, 11 psi both rear, and 10 psi front right from cold to hot. So if targeting say 39/40 front/rear, I'd have to start the session with 27, 29, 29, and 29 - but your results will vary on track and driving level. I'd reset the TPMS and let it re-learn. It will tell you you have a problem, but once you pull the stalk, it shouldn't scream at you.
Not so in the 997... PSM if off will only kick back on if ABS is engaged (1 wheel ABS if no Sport Chrono, 2 wheels if SC). Also, if you have SC, the levels will in increased (ie: more yaw) to give the car more freedom. At least that's how it was on my 997S. PSM still monitored everything in the background, but would only kick on if ABS was engaged AND the car was in a position where PSM thought I wouldn't want to be (ie: sideways).
I had PZero Rosso's. IIRC they don't grip well beyond 40 psi hot and then they are pretty greasy feeling. I overheated mine and they chunked. I replaced them with Yokohama ADVAN Neovas and compared to the Pirellis I think they are much better tires. Better grip all around.
Matt
