Spinning Hoosiers?
My tire guys laughed at the idea of hairspray. The rears rotate about 180 during the day - the next morning they are square for a few laps, then OK. Rebalancing is a waste of time unless you are flipping the tires for better wear. IMHO
Hey Streak,
First use alcohol or solvent to get the rim surface and tire bead clean (you've got to get off the mold release from a sticker tire), then spray some hairspray (I use unscented Aquanet so the tire shop doesn't smell like a beauty parlor) on both surfaces. Mount, balance, and you're good to go.
Next time you see Kurt M., you can thank him for this trick.
Perfect Angel
Hey Streak,
Gary,
Actually, when I had them rebalanced both the rears hopped. Maybe from sitting after a session?
Mine spin alot on the fuchs. Woodmann mounts them dry now. Doesn't seem to be a problem with 16" rims, gets tougher with low profile and larger rims. Spent a year at club races trying to resolve the issue, this seems to work best. Another solution was to get tires sent to house and have them mounted a month before race with water versus soap. This worked good too, but was inconvenient when you wanted new tires on Saturday afternoon before the Enduro. Good Luck.
John do you think that happens when the tires are not up to full temp and the pressure is low? I have never check to see if this is happening and every time I see this topic i remind myself to check it out on my tire rim set up. what do you do just run a chalk line on the tire?
Perfect Angel
Excellent question. It has been suggested that higher pressure may help. I did have the tire guy remount them with the hairspray trick.
My pressures were between 36 and 39. Would staying closer to 38-40 help?
Hunt,
Mine do this all the time and it does tend to throw off the balancing a bit. It is under braking for sure. I mark the tire w/ chalk next to where the valve stem is to see just how much they are rotating.
Have your shop dry mount them or try the hairspray as lube trick.
Frank,
I use a paint marker and mark where the valve stem is. I also mark the wheel weights, i.e., make a mark as long as the the weights on the rims so that I know if I get a vibration whether a wheel weight flew off or the tire rotated. Saves a lot of nervousness when a vibration pops up and you're trying to figure out what is causing it.
