Wheel Weight trape source???
Guys, I keep slinging wheel weights off and I need to get some heat friendly tape to hold these down. Seen the stuff before, but don't have a source for it...
Mike
Mike
Get the foil tape from an HVAC specialty house or an HVAC contractor.
The stuff they sell in Homo Depot is lousy and comes off......the good stuff doesn't, but it's expensive.
Administrator - "Tyson"
How much does the weight of the tape throw off your wheel balance?
Mr. Excitement
Look for the large roll with printing on the face fo the tape. This is the rated tape. Homo Despot sells it. The little rolls in blister packs is the thin cheap home owner stuff. If you want to get real sig line impressive use Stainless steel tape.
Yep.. At Hoosier East I asked them not to tape the weights (they used purple duct tape last time) because I use metal tape. They said "no problem, we have that and will do it for you". Great! At the Glen race I see a nice strip of metal tape, with weights stuck to it, laying inside my wheel. Taped RIGHT over the dirt they did! Clean the wheel up like new, THEN have them balanced, then DIY...
Thanks much Guys!!
Mike
Mike
Member - times 3
Member - times 3
