Ideal weight balance - F1?
F1's weight bias is not at all comparable, simply because they're limited so much by tire sizes & aerodynamics. I believe that right now they're actually running a bit of a front weight bias as the rear tires are too small and already overworked.
The cars have an obvious front end drop when hoisted by the cranes, but this is probably more due to the rearward location of the crane hooks.
I remember Steve Machett saying something about this a few years ago. He explained that the theory used to be more rear weight bias in F1 cars, but has since been changed and the theory is that more front bias is preferred to keep more weight/grip on the nose of the car, and acheived with moving the ballast up front. Not only does this help with turn in, but saves more of the rear tires from degradation during a race stint. I believe Renault was one of the teams to use it first prior to Alonso's first WDC.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I agree that they probably have moved the bias forward a bit as the handling of the car is better understood year to year. I would also think the the weight bias is set up fo maximixing performance in the slower parts of the track when the aero bits are less effective.
I think I read somewhere that the older 911's had as much as a 40/60 split. Can any of you 911 guys give us your numbers??
Isn't one of the problems Porsche is dealing with in Rolex and other major racing series is rear tire degredation in part due to the weight back there?
Eddie, it actually started life at 36/64. It's tough to get much better than where mine is right now without ADDING weight to the car and locating it in the front boot.
F1 cars have ballast via thin heavy plates mounted as low as possible in the chassis,
and they are movable fore and aft to provide different weight distribution for
different tracks. For slow-corner tight courses like Monaco, they shift the weight
somewhat forward for more turn-in mechanical grip.
Do you still have the stock battery located in the original position?
I've seen some cars with either the original sized battery or a smaller racing battery located in the floor of the trunk. If you're not worried about regulations etc. it seems like a good way to help with the weight balance issue.
Can't put the battery down lower as my Cool Shirt box was just installed this week in the front boot. The battery is in the original location but has been changed out to a lighter battery.
