View Poll Results: Oil consumption per track day
0 to 0.3 quart
30
68.18%
0.4 to 0.6 quart
10
22.73%
0.7 to 1.0 quart
2
4.55%
1.1 to 1.5 quart
1
2.27%
Over 1.5 quart
1
2.27%
Voters: 44. You may not vote on this poll
911/964/993 owners - how much oil consumption at the track?
RL Technical Advisor
Eric,
Do a leakdown test to confirm that its not rings or valves. Pull a lower valve cover to do the "wiggle test " and check guide wear.
Although you are emissions exempt, oil consumption leaves heavy carbon on piston crowns and combustion chamber surfaces. These create hot spots that trigger detonation and pre-ignition which are a BIG problem for anything with forced-induction.
