power to weight or just more HP????
#46
you need more tire ACTION! 44psi!!?????? you need to be in the 38psi range hot. with the bigger meats, you might need to start out at 28psi to get them working and then drive the snot out of them too! the skinny tires and fat tires are quite a bit different. also, look at set up. you migh have too much camber or something for the fatter tires. so many factors, so little time!
Mk
Mk
Compared to most, I'm already on a strict camber diet, I run 1.75 in the rear, I think I'm at 2.25 in front, but perhaps its not a bad idea to experiment with a tick or two less. This setup thing is indeed a PITA, but hopefully we'll get a little closer before the end of the season.
#47
ok, so after all the physics talk...lets use a simple car comparison...
996 gt3 with 395 hp and around 2950 lbs VS a 996 turbo at 3400 lbs with 430 hp (so there isnt a HUGE amount in between the two, but noticeable). Assuming that the turbo had enough suspension work, how do you think the scenario would play out at different tracks?
(reason why is I have both currently in the stable...and feel like the gt3 will be faster nearly everywhere...short of MAYBE 160 plus (which is very rare to hit anywhere other than pocono or VIR)...
Depends on the track. I'd bet money a 996 TT would beat a 996 GT3 at the high speed tracks if the TT were allowed coilovers, rear sway and camber adjustment only. Same tires, same day.
But as for the overall theory, the lighter weight car with the same weight to hp ratio, similar aero and suspension setup will be faster on most any track.
#48
Notice how our ooompa loompa friend has not reappeared in this Track/Racing section since he had his head handed to him in this thread?
I am sure he is still pontificating mightily and dangerously to the unsuspecting and naive in other forums here, though.
#49
Hey, wanna911, when you go to visit your buddy Michael Vick in prison, and he complains about prison food, show him this:
#56
I have to agree with VR on this one.
On a big track like VIR or Daytona a lighter and lower HP car will get its a$$ handed to it while on a tighter smaller track like CMP it could be the other way around.
#57
As a personal example when First Settlers does its 3 day event at VIR with the first 2 days on the North Course I am much more "competetive" with my higher HP bretheren but on day 3 when we use the full course and the big HP cars get to stretch their legs it's sayonara time...
#58
Same at TWS...as in the personal example I gave earlier in this thread when kicking 02 Carrera to the curb.
Whereas, it is likely the be the other way around on a technical track like Motorsport Ranch.
#59
1 Post
Not sure about this. How do you account for the Mazda RX8 in Grand Am? I think this may be a pretty good example, although I'm not sure about the HP/Weight ratio. I believe that everyone is missing out on torque and gearing, which is what NASA GTS accounts for in some ways.
#60
I am so damn close to finshing the car. Could tune as soon as Friday.
