Yeah, baby, I've got air!
Old 06-04-2008, 11:02 AM
DogInBlack
DogInBlack's Avatar
Looks cool to me
Old 06-04-2008, 11:03 AM
Bryan Watts
Bryan Watts's Avatar
Originally Posted by schvetkaaks
In driving my car, I can tell you, there's little to NO chassis flex.
There's probably a lot more chassis flex than you realize, just not in the way that you think. You can see the difference in roll couple between the front and rear of your car in the pictures you posted. The front seems to roll more than the rear which puts a large twisting force on the chassis.
Old 06-04-2008, 11:06 AM
schvetkaaks
schvetkaaks's Avatar
But isn't the front experiencing a different type of force since it is full throttle, with weight transfer all the way to the back? A stiff chassis would make wheelies (to use a childhood term) if there was enough speed/g-forces/weight transfer to the rear. A flexible one would remain planted, as demonstrated by the street cars, no?
Old 06-04-2008, 11:08 AM
schvetkaaks
It's front springs and bars stiff to the point that there's not enough rebound travel to keep the wheel on the ground when the car rolls and front suspension geometry that actually increases it's tendency to roll the lower your ride height (since the roll center drops much faster than the center of gravity) Personally, if possible, I like to keep all 4 wheels on the ground. I don't find tires in the air to provide much benefit.
There's no benefit at all, and frankly, at this corner, it's likely wheel hop based on the horrible conditions of the track - that corner is covered in bumps in that direction. It's likely a small jump, really, but it looks kick ***.
Old 06-04-2008, 11:11 AM
DrJupeman
DrJupeman's Avatar
How many pictures do you want to see of my car doing the "fire-hydrant pee" on an apex? I've got a crapload of them. Not much I can do to adjust the car to correct for it, either (spec class, basically).
Old 06-04-2008, 11:18 AM
stuttgart46
stuttgart46's Avatar
Great pic Todd. I love seeing the Boxster driven in anger.
Old 06-04-2008, 11:19 AM
rickdm
rickdm's Avatar
I couldn't quite figure out how to post a pic, so i thought I would put it in the avatar. The shot is at Eagles Canyon on turn 7 where it is very bumpy, I don't think my wheel lifts that much under normal paving. I do think it is somewhat caused by a 22mm front torsion bar fighting a 31mm front sway bar.
schvetkaaks
Did you see the vid? Talk about 'in anger', lol
Old 06-04-2008, 11:25 AM
Bryan Watts
You are cornering at 1+ G and only accelerating at a few tenths of a G. Most of the forces acting on the chassis are from cornering loads. Carrying the front wheel has a little bit to do with being on power, but most of it comes from the limited rebound travel that you have in the front suspension that can't make up for the amount that the front of the car is rolling.
Old 06-04-2008, 11:32 AM
schvetkaaks
Is that because of springs that are too hard (1300lb front) or lack of travel distance of the front rebound?
Old 06-04-2008, 11:44 AM
dbryant61
dbryant61's Avatar
All chassis flex, just like all beams deflect. It looks like yours (Todd) has a very well thought-out cage and that will limit flex greatly. I think one of Porsche's, espcially the older version 911s, big advantages is the stiffness of the tub. The steel is much thicker than that of modern cars. I think wheel lift is much more related to suspension. Most of us run smaller ARBs in the rear, or at least have them set softer, so that we gain rear grip for earlier throttle in the corners. The result is that most of the roll resistance in the rear is being done by the outside tire's t-bar or spring because the t-bar is ont transferring as much force to the inside t-bar or spring. Coupled with acceleration throwing weight to the rear, and you have outside rear corner squat. That coupled with less weight on the front naturally, weight removed from the front by acceleration, and a stiff front ARB lifts the inside front. The line connecting the inside rear and outside front is like a fulcrum.
When I first began working on my suspension, I installed 22mm ARBs F&R with stock t-bars. I could feel the outside rear squat like crazy, and others claimed my inside front was 6" off the pavement and would actually come to a stop in the air. Sorry, no pics.
Old 06-04-2008, 12:02 PM
Bryan Watts
They are one in the same....the stiffer the spring, the less rebound travel you'll have. Let's think about it, what's your corner weight up front? I'm just going to pull some numbers out of the air...let's say your car weighs 2500 pounds with you in it and that your car has a 55% weight bias towards the rear (it may be more than that?). So, making an assumption that the car is R/L balanced up front, you have about 560 pounds of weight on the front-right corner at static.
You have a 1300 pound spring mounted on a strut, which means your wheel rate (using around a .90 conversion factor from BMW's) is something like 1150 pounds. So, at static, your spring is being compressed approx 1/2 inch (560/1150 = 0.49). This doesn't even take into account the wheel rate added by your anti-roll bar or the fact that the front spring is compressed even less when you are accelerating and weight is transferred to the rear.
So, you have less than 1/2 inch of rebound travel in your front suspension. Unless you car rolls less than 1/2 inch in the front, the inside front tire is no longer going to be in contact with the ground. Due to the crappy roll centers you end up with when lowering a strut suspension, even a 1300 pound spring isn't enough to limit your front roll to less than 1/2 an inch.
What does all of this mean? I think all of you Porsche guys run too stiff of spring rates.
Old 06-04-2008, 12:18 PM
himself
himself's Avatar
I've always wanted a shot like this, with a front tire in the air...(talk about stiff suspension...)
Nice pics! Great paint job! I think it's a matter of rear shocks having too slow rebound combined with front sway bar being too stiff. But what do I know.
At the last DE here, some of the pics look like I'm about to have 2 off the ground. Other pics (without tire lift) posted here.
-td
Well, not tire lift, but I like this pic.
Old 06-04-2008, 12:19 PM
sbarton
sbarton's Avatar
Bah, only one tire in the air? How about 2!
-Scott
Old 06-04-2008, 01:00 PM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
That's why you run smallish (or stock) sway bars and helper springs when you run really stiff main springs. Keeps the inside tire on the ground.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Quick Reply: Yeah, baby, I've got air!
