SCCA APPROVED BOLT IN ROLL CAGE
Is there an SCCA approved roll cage that can be bolted into an 82SC that does not require any welding? I have checked Autopower but even their bolt in kit requires welding of the door bars. Plan is to run Improved Touring (ITR)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I'll provide the inevitable "You really don't want to do that" post:
You really don't want to do that. While I have no problem with bolt-in cages in light weight, low powered IT cars (crash tested several myself, including a "total"), the cars in ITR require different consideration.
Not only are the cars in ITR bigger and faster, but you'll also be sharing the track with other "big bore" classes like A Sedan, GT 1-L and D Prod. Those things are also bigger and faster, and the inevitable multi-car incident is going to involve more energy than a bunch of beater ITB cars.
You need to re-think this.
Not only that, but you're giving up performance with a bolt-in. Use the cage as a means to add a lot of rigidity to the chassis while also placing weight where you need it in the chassis to meet min weight and achieve good corner balance.
