Options for a new Trailex open trailer?
So with so many Trailex fans out there, what would you recommend to someone who wants to order a new one? I think I will hold off on the tire rack for now.
I am thinking of getting the CT-7541SB with
Does anyone recommend the front shield? I don't love the idea of extra rock chips on the front of the GT3.
Thanks,
Chris
- Aluminum wheels
- Aluminum spare tire & carrier
- Aluminum tool box and mounting kit
- Longer 9' ramps
- Black reflective striping
Thanks,
Chris
All looks good except for needing two spares and mounts. I like my tire rack, but you may have other plans. I also have the tool box, which is good for storing tie down straps, wheel chocks, etc.
I don't have the front shield and have never seen a stone chip problem in 6 years with two different cars. It appears the shield will add to the difficulty of tying down the front straps, even with the zippered ports for doing so.
BTW, several of my friends are happy with the new welded Trailex trailer, which saves about $1000, but does weigh a few hundred pounds more.
Thanks,
Chris
- Aluminum wheels
- Longer 9' ramps
Thanks,
Chris
Lastly, I bought my own refelctive tape for 30.00 and put it on myself.
I'd agree with Bull as regards the front shield; skp it. After 4 years of towing with no shield, I've had no damage, superficial or otherwise, on the track car finish. (Track chipping, however is another story, hence the addition of clear bra on the rebuilt and repainted car). Then when you think of all the work and general messing around you'll end up doing around the front end of the trailer, checking the straps while towing & refueling, loading and unloading, you'll be glad it's not there.
No advice on the trailer, but is it just me who likes to see the car sitting on the trailer in the rear view mirror? I'm afraid if I had a stone shield, I'd get to the track and my car would have fallen off 200 miles behind me...
Thanks,
Chris
- Aluminum wheels
- Longer 9' ramps
Thanks,
Chris
I haven't needed the front shield, although I may get one in the future in the hope of keeping rain from filling up the open car I tow.
I got the 8045 for several reasons; I have 2 cars that weigh about 4200 pounds that could go on the 8045 and not the 7541, and it worked better with the 2 really low cars I mostly wanted to tow, a 996 with GT3 suspension and a Radical SR3 with less than 2 inch ground clearance. If you look at
http://www.trailex.com/showspec.cfm?...txt=otspec.txt
the specs show the 8045 has the lowest deck to fender height (so the 996 doors open over them), and it also has the biggest ramp to deck height ratio (along with the 7031) which reduces the angles between ramps and both deck and ground. Frank, I'm surprised you need planks to get a GT3 on and off, as I don't, but you say you have 8' ramps, and mine came with 11' ramps (like the spec sheet says).
Maybe Trailex has been changing the specs; a year ago you could have the 8045 axle in a mid or rear position (like the 7031 in the table) and I opted for the rear position. Compared to my 996 on the trailer, Frank's car looks like it's sitting way forward relative to the axles; if I placed mine like that I'd be way over the maximum 200 lb tongue weight that Trailex wants. Maybe they changed something else as well.
Getting it delivered took some time; I was ready to buy in December, but had to wait till March to get delivery combined with one going to Tucson and another to San Antonio, and even then I picked it up in Tulsa. 1400 miles from Trailex in Ohio to Austin at $1.50/mile would have been significant.
Anyway, I'm happy with mine, it tows very stably behind my huge overhang, marginal GCWR tow vehicle.
Michael
Get the tire rack for track tires.
+1. Before I pushed the plunger all the way down and injected myself fully, I almost made the tragic mistake of selling the tire rack of my used Trailex. Good thing my friends stopped me.
Trailex does not have a 200lb tongue weight limit for my 7541, which I run with approx. 400-425 tongue weight.
We have a Trailex dealer in our PCA Region. He orders 4 or 5 at a time and saves everyone some shipping costs. When he orders for a customer with a 911, he just tells Trailex that and they have a set-up they use for the trailer....axles in rearward position, long ramps, etc.
Another vote for a tire rack. I don't have the front shield, and no rock chips from that. However, the one really nice thing about the front shield is it keeps the car much cleaner when you tow in the rain.
The tow vehicle is your stone shield. Two spare mounts and definitely get the tire rack,you will use it and it will help with resale.
You still see your car with the shield. Ive never had a trailer with out one so I cannot compare. No damage towing though... First few times I used it I would forget and think someone was following me.....
Well, I ordered my Trailex today from Carl. He got me a good deal on freight and I should have it in about 3-4 weeks!
They are giving away the free Aluminum Wheel upgrade and a Spare Tire Carrier for orders in May. Great deal!
Thanks for your suggestions.
Chris
Chris
Congrats, they work so well. after I bought mine I went out and bought some RED/White safety tape so that it sticks out and night. I think that Northertool had some set up for doing trailers. I also bought Tire locks, NAPA sells some good ones that worked well.
