Tire Pressures for 964 wearing PS2s?
Moderator
Posted last week at 964 and didn't get any replies. I'm planning to burn up the PS2s that came on the car before buying a set of PSCups. Any tips on optimal pressures for:
964 running JIC suspension, RS Sways, RS ride height, -1.8 front -2 rear camber.
BBS 18x8 front with 225 PS2s and 18x9.5 rear, 15mm spacer, and 265 PS2s.
I found a few references using a search suggesting 36/42 for 18" wheels / tires on a 964, but then other references to 36/36, and others in the middle. I'll figure it out my first track day, but thought maybe somebody had some wisdom to share.
While I'm at it, once I have the PSCs on, I'll use the oem 17" Cup 1s with 225/255 Bridgestone RE050A Pole Positions as my heavy rain / extreme cold tires. Manual says 36/36 for 17s - thoughts?
Thanks!
Thanks!
1 Post
Ron, I've found that about a 3lb difference front to rear works best for me in the 964. I run 18's also. I typically start out cold at 28 front and 31 rear and they'll usually gain around 8lbs when they heat up on the track on a warm day. If you see anything higher than 40lbs hot, then you will probably notice it starting to slide around too much.
But I'm no expert so take this with a grain of salt.
