Autobahn Country Club corner numbering?
I have two different corner numbering systems shown for Autobahn full circuit track.
One map shows sequential corner numbers from 1a to 21.
The other full track map shows the North track and South track corners numbered as if they are separate: the North starting with 1n and ending with 9n; and the South track starting with 1s and ending with 15s. Which numbering system is usually used for the full track?
I'll also be driving the N & S tracks separately. The separate N & S maps I have show them numbered from 1 to 9 for the North, and 1 to 15 for the South. I assume those are correct when driving only one area?
To be honest, even when driving full track I still mentally think of the turns as North/South, i.e. North 3, South 6, etc. I'm a member at Autobahn, and I think if you asked someone what line they take through turn 17, they'd have to sit back and do the math to figure out which turn you're talking about. I've never heard anyone refer to the full-track turn numbers sequentially; they're always referred to as North <whatever> and South <whatever>. So keeping the separate North/South maps in mind is probably the best bet. In the full-track configuration N 1 & N 2 go away, and are replaced by "Link 1" (some track maps may still show N1, but N1 is really just the entrance to the Link).
1. you will have to option to take N3 using a very different line when running the full course
2. link from N to S going around the club house can be perilous... very perilous.
Good luck out there.
+1. There are only two things to really keep in mind when thinking about the differences between N, S, and full track:
And I'd add: 3. On the straight between S and N (coming up to N3), remember to get left early, otherwise you'll get some air time as you go over the rise (assuming you're carrying enough speed).
Another tip: careful through S3; it's not a challenging turn, but the barrier is close on both sides so a small mistake can result in big damage. That turn probably claims 90% of the cars that get damaged out there.
But anyway, how about this one: You tube RSAE Milano Autobahn Country Club video
(I couldn't figure out how to attach a link).
Cobrien, I haven't figured it out yet, but I bet there is a way for you to send a large file that I could edit. I have Nero for editing. (Haven't used the video part yet, but sure I can figure it out).
So many turns in the full course that I actually taped a map of the track to the dashboard the first time I ran there...
True story, you can ask folks who were there...
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
+1. I remember seeing an 1,200 mile Challenge Stradale planted in the barrier right there. Apparently $120k in damages to the car.
Another +1. I watched a Cobra replica drop a wheel and shoot across the track & smash the armco on the left (inside) of S3. Seeing that so close scared the s**t out of me ...
