How much faster is this?
Two similar stock 996 GT3's.
The course: 1:30 second track with a lot of twist and turns, short straights.
GT3 #1: Stock wheels with 1/2 used Toyo R888
GT3 #2: Lightweight wheels (possibly Kinesis wheels) with new Hoosier R6
Question: Assuming similar drivers, approximately how much faster per lap would you expect car #2 to be on this type of course?
Why don't you run have driver 2 run the session and then come in and put driver #1's wheels on his own car and see? That is the only way to really tell.
On a 2min track I have seen a 3 sec difference personally moving from a Nitto NT01 (same comp as R888) to a R6 on the same wheels.
This gives me some baseline. Dell, were those times with the same rims? The less unsprung/rotating mass has to account for something too.
Well, from personal experience, I ran with my good friend Chris L at VIR recently and my best time on R6's with stock wheels was a 2:06 and his time on Pirelli slicks with Fikse Motorsport wheels was a 2:04.3. Then I moved to slicks (scrubs actually) on BBS Motorsport E88 wheels and ran my fast lap of a 2:04.8 so I would say that we are very similar in time at VIR. I have no idea what I will run on a new set of Pirelli slicks (I will at Zone 2 :jumper) but I can't imagine it is more than a second give or take.
So with that data set, I would say 2 seconds?
- beginer driver - no difference
- 25 trackday experience - 1 second
- fast driver - 2 seconds
I wouldn't attribute anything more than a 1/10 or two to the lighter wheels.
Same driver might not produce total obtainable results with a single run of one or the other. You need to use all that a tire has to offer in order to get the best lap times. Same driver might drive the sticky tires using the same methods he is used to with the less stick tires.
Same car, same driver, same conditions, one day each.
The above is a truly bad answer BTW.
I do not believe you will see a difference in lap times from the wheels as this time delta will be smaller than the typical lap to lap variation on most drivers (even very solid ones).
I tried to heed the advise of y'all and stay away from the crack called Hoo Hoos, but I don't like being beat. I was out "tire'd" and wanted to know the approximate time delta.
Now that the whole reason came out I would say 1.5 - 2 seconds easy. Yes you got out tired, join the club. And when you finally make the move to Hoosiers your friend will jump to slicks and let the financial carnage begin....
I can't make every time trial so I'm not going to go for the season point competition, but I was just curious. My thought was roughly 1.5-2 seconds as well. I'm going to stay away from the crack...... for now....
Ah the pull of competitive driving. You do your qualifying and your competition is .5-1 second faster. You KNOW there's 1-2 seconds in that new set of $1,000 Hoosiers. Do you take you chances at getting beat or buy the tires?????
Remember, that 1-2 seconds is only good for about 6 laps.
Me? I'm focusing on trying to find that 1-2 seconds in driving technique...well, until the race anyway. Damn! Those new Hoosiers look fast....
I had a student recently in a T1 Vette that was schredding his tire with the sidewall of the rear fender and was smoking really bad so we were blacked flagged (session1) and came in. So when we got into the pits we (me and the event organizers) took a look and his fender was coverd in "drippy" rubber and his tire felt like hot gum that has been on the pavement in July for hours. You could literally depress the rubber. Low and behold it wasn't a R6 he was running but rather a A6!!! I explained to him that was an auto-x cross tire and intended for 1 minute run NOT a 30 minute session!!! He promptly told me that "ALL THE VETTE GUYS RUN THIS TIRE NOW". Unfrickenbelievable. Needless to say I didn't go back out with him (there were other safety issues inside the car that I won't get into here).
