964 17" track tires?
I need suggestions for the preferred tire set up (17x8.5" 17x9.5" wheels) on a C2 with race suspension.
The ideal would be Hoosier but they don't have the correct sizes. Ideally I don't want to bash in the fenders to make the tires fit.
Lifetime Member
Lifetime Member
Fellows, the thought of 245/275 Hoosiers on this old narrow car is an exciting one.
As a final comfirmation, the general consensus is I can use 17x8.5"/9.5" 50MM offset wheels with the 245/275 Hoosiers under the factory bodywork? To the best of my recollection the camber is negative 1.5 for and aft.
Ideally, you want your track tires/wheels mounted when the ride height is set, along with a corner balance and alignment. That way you can ensure yourself of a good fit and proper alignment.
