Yet another Sub Belt Routing question...
#33
In the case of a floor, it will, no question. Probably the seat too, although I'm guessing there will be some lessening of that because the load follows a more complex path and is spread over more and differing structures.
As I said, I am mulling over updates.
#34
John, don't underestimate the benefit to your design. Keep in mind that the floor pan can be compromised something other than pull from the sub. It could see an underside impact, collapse upward in a heavy side impact, etc. So when bolting to the floor you need to consider primary (sub-pull) and the secondary mentioned above. It may very well need to be twice as strong as the seat to outperform your set-up. I guess what I'm saying is that even if both failed the jack test, I'd rather have your set-up because it only sees sub loading.
The only reason I don't like mounting to the seats is typical the mounting methods aren't designed for it and if those fail then the entire driver restraint system is compromised.
#35
#37
#38
There seems to be something missing in this discussion that is an important consideration when thinking about load distribution. While the sub strap(s) may experience the same load as the shoulder harness, the question is over what area is the load distributed? Using a single mounting point reinforced by a 4" square plate is much different than a single bolt and 1" diameter washer.
I understand the rationale for mounting sub straps to the seat (JH configuration) or the seat mounts (Chrisp), but there will still be a load placed on the floor pan via the bolts that hold the seat rails in place. I am not saying their approach is wrong - it's just that the analysis doesn't stop with where the strap(s) are mounted. John's mounting is complex because their are two areas that can deform - the seat and floor plan. I would prefer Chrisp's set up provided his seat is mounted to the floor and well reinforced along those mounting points.
Shroth offers excellent instructions on proper mounting of 6pt harnesses" http://www.schrothracing.com/docs/Co...structions.pdf
#39
You are right. It was kind of a given that the seat is mounted well. Amazingly I see many really good cages many done by DIY'ER's but what I rarely see are seat anchors tied into or integral with the cage. That is really the best way so that if you get a unibody deformation the seat stays inside the capsule of the cage. It is really bad if the unibody collapses and takes the seat via floorpan with it only to have the driver hit by the cage.
#40
You need to factor further. Speaking of flat panels like a floor, especially loaded at an obtuse angle, the amount of backing is irrelevant to me. Using a flat floor in any event is not sufficient in my estimation.
The only effective difference with a 1" or 4" backing of a bolt is that the 1" will tear through the sheetmetal sooner. However, the distance that both mount points travel under a deforming load (short of failure) will be similar over a large portion of the deformation. The SHAPE of the deformation will be different, but the distance will not be different enough to matter, I'd wager.
Only when the surface area contained by a flat panel mount reinforcement begins to activate a structural component - like a center tunnel, inner rocker panel, roll cage tube, etc. - will it begin to gain significant enough strength to make a substantive difference in travel. In other words, you would need a plate that was thick/strong and/or large enough to activate one of these structural members before it would interest me as a valid reinforcement for a sub mount.
My rule of thumb is no unreinforced sub mounts in floor pans. Of course that makes for a lot of work, but... that's what I do.
#41
You raise some outstanding points, and those are all factors that go/went into my decision. Another is keeping the sub belts the same for vastly different size drivers, which is something normal narrow rules don't account for very well.
