Racing suspension advice - 911SC
I am preparing to do my suspension again, and am writing to ask those on these lists for advice on t-bars and anti-roll (sway) bars. I did this two winters ago with 22 & 28 torsion bars and Weltmeister 22mm anti-roll bars (which will be for sale when I am done). The purpose of this step is to make the car full race to run in PCA G-class, NASA GTS, and possibly SCCA ITS. Once I decide on bar sizes, I will be sending the struts and inserts to Bilstein for custom re-valving.
I am pretty sure that 23mm front torsion bars are the standard, but would 24 be better?
As far as rear torsion bars, I have heard everything from 30 to 33. I really do not know where to go here.
Finally, anti-roll bars. It seems that Tarrett and Kokeln sway bars are hollow equivalents (same torsion rate) of the Weltmeisters. However, the Smart Racing bars are available much thicker. I really need your help here.
I realize that I could just go with the Smart Racing track setup (23/32 t-bars, 31F 27R ARBs), but this setup is listed for a wide range of vehicles, showing no differences for weight or power.
Thanks in advance for your advice.
Don Bryant
Don Bryant
Basic Site Sponsor
Basic Site Sponsor
Having run a Carrera with 23/31 T-bars and 22/19 Sway Bars I would run the biggest T-bars I could get if I were to build another. I know that there is info out there on what exactly the spring rate is of T-bars on the 911. They are surprisingly soft IIRC.
As an aside, I had my Bilstien sports revalved by the factory to match, and it came out great.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Lifetime Member
Lifetime Member
I am using 23/33 Sanders (drilled/hollow/ or whatever you call it) in the SC. Double adjustable shocks with more rebound and Smart Racing Adjustable sways. A well known pro did not like the 23 and recommended I switch back to the 21mm. I tried the 21s for two events through a range of sway and shock settings and went back to the 23 baseline to try and home in on the solution. The rear rebound is really crucial to threshold braking in areas like the back straight at VIR and Mid Ohio. With stock Billstein Sports the car moved around quite a bit under hard braking. I have only just begun to understand the effect of more/less compression/rebound. I have read the Puhn book more then a few times and would like to find more information. If anyone has a recommendation on reading material on shock set-up, it would be really helpful.
Basic Site Sponsor
Basic Site Sponsor
The caveat with having a pro setup your car is that you must like the way they drive and how they expect the car to handle. Otherwise, they will be setting it up for themselves, and you will not feel comfortable in it.
I'll throw out a baseline for consideration for a D class SC (used to be G class).
Torsion bars: 23F/31R
Sway Bars: 31F/27R Smart Racing
Shocks: Bilstein valved to match (this can be shop dependent and does effect ultimate performance greatly)
Bushings: All bearing or solid bushing
Although nice, canister shocks are probably not necessary to run with the big dogs (which I'm not)
Brian, thanks for the support.
Larry, Did you feel your sway bars were sufficent? I may try the 24mm front t-bars and whatever the thickest rears are and not change sways if that will work.
Alan and Chris, thanks for the input.
Don
Don
Basic Site Sponsor
Basic Site Sponsor
Don, if it were me I would install the 24s & the 33s and see how it feels. I would then evaluate a sway bar change in light of the balance of the car. My old car understeered somewhat, but back then they really didn't make a decent rear sway bar, so I stayed with a factory style 19mm bar that I found, with a 22mm weltmiester front.
Basic Site Sponsor
Basic Site Sponsor
I do not know anything about the job that SRP does, but based upon reputation, it should be good. Because it is an art as much as a science, you would get 2 differently valved setups, and it is difficult to know which would be better. The 3 way Motons on my car are incredible. Knowing how well I can dial them in, personally I would go with the least expensive decent quality 2 way shocks over anything fixed.
Larry and Gary,
Thank you very much for your input. Larry, I get what you are recommending: the carwill benefit from the stiffest "spring" I can find, and then use to sway bars I have to tune over-/under-steer. These suspensions are so far away from the 1400 lbs/in springs they run on the Cup cars.
At the risk of being convicted of blasphemy, I have heard that a few G-class cars that came out of that Hairy grrrage have questionable parts allowing 3.0 deg of negative camber. Anyone care to confirm? The best I can get is 2.0, the car is very low, but all holes and ball joints are in their original locations.
Don
Don
Basic Site Sponsor
Basic Site Sponsor
I don't know about what Dan uses, but I got -2.5 degrees out of my car by moving the struts to their innermost factory position, and then tightening the strut brace to suck the fenders together. There was very little fender gap when I was done.
