VIR - breakdown of corners and proper line?
#46
[QUOTE=LVDell;4757113]168???? Are you serious???? DO you have data aquisition to confirm this? What are you driving and what mods do you have. Pushing 170 is quite some feat. It take alot to get over 150 in a non grand-am car.
Definitely...its not even hard to break 150 as I do that IIRC near the damn hill(a bit after) and 5th gear is really, REALLY strong in my car...170-175 is probably where Ill max out at when I get through Oaktree a bit faster. I hit low/mid 180s at Pocono running reverse IMSA (THATS fun). The TT is a VERY potent beast (which is why I think it makes a GREAT racecar if the track is fast enough and the suspension is tuned correctly).
But ya...again, hellz no on the no lift for southbend...haha
#47
Assuming the original poster will be driving his 993 TT he will need to lift for the Esses and brake for SB. Also, the curbing isn't a big deal as long as your wheels are straight (IMO).
#48
#49
maybe some people were confusing t10 with one of the turns in the esses?
#50
Mr. Excitement
sounds about right, but that might even be pushing it...i guess its dependent on how fast you can get that car through the esses...i can't imagine someone going flat through soutbend in a cup car knowing how fast those cars can get through the esses...
By the way, thanks for your advice on the Z214's, Dave.
-DS
#52
#54
What do you end up before the brake zone? 160?
btw, my readings were only the speedo readings, not a GPS verified speed...BUT, I never looked what I was acutally at when I hit the brakes, I would look maybe 300-500 ft before the zone even starts.
#55
I am in the low 150's when I jam the brakes. I think 153 is my top speed so far. I brake just after the 1 marker (between the 1 and the *). My exit speed at Oak Tree is pretty substantial. I think the problem with the GT3 is the long gearing. IT BLOWS!!!!! One day soon I will change out my gears. I don't need to or ever envision a time when I need to hit the 190+ top speed. I much rather drop my top speed down in the 170's so I can get through the gears faster.
I'd have to check my Traqmate data to see what my exit speed at Oak Tree is. All I can remember off the top of my head is that it is a 2nd gear corner for me but I treat the entire double apex as one sweeping corner.
#56
Ha Low 150's !
On a good day I'm in the low 130's with my foot through the floorboard although my exit speed comming right out of Oak Tree is probably close to yours Dell
(note to self, ask Santa for more HP !)
#58
Eddie, be nice and Santa should bring you something
As for the Oak Tree speed. I just looked at my Traqmate data and my entry/exit speed at the apex of Oak Tree seems to be about 45mph. I have no idea if that is good or bad. But it sure feels fast as heck.
#59
ya, gotta be the gearing cause, like I said, even when I wasnt really moving it around there, I could hit 150-155 without any particular "strain". Def get some gears!!!
