How long will a 996 hold an alignment?
Hi all. I am told stories about 996s not keeping an alignment very long
under race conditions. Assuming the alignment shop does race cars,
and tightens things assertively, how long should I expect to keep the
settings reasonably close? The car is a full-weight car, and isn't driven
over horrible roads, but is street-driven to-from... Are there any tricks
or parts that will nail down the alignment more durably, or is this all
hog wash?
thanks
Joe
hog wash?
thanks
Joe
Basic Site Sponsor
Basic Site Sponsor
I have aligned 2 GT3s for the track, my old one and my friends. Both are/were driven on race tires and neither lost their alignment, even when pounded over the curbs at various racetracks. I think that if the rear eccentrics are properly tightened, and it's a bitch to get them really tight, then they will hold just fine. Once the knurled surfaced gets stripped smooth because they have slipped, they will no longer hold a setting and you need to change to a turn-buckle type arm, like the cup cars have, IMHO. To answer your question more directly, I would say that the alignment should hold for the season.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
There is a safety issue with the rear ball joint bolts on the 996 though. That's why there's a proposed rule to allow GT3 control arms. I really hope it passes.
I don't believe it's the function of the eccentric to hold alignment at all; it's just there to alter the pivot point of the lower track control arm and the toe control arm while the alignment is being performed. However what DOES happen is that some people who do alignments don't have the 18mm S-shaped ring wrench that you need to tighten up the eccentric bolts properly, and so they improvise, and the result is that these bolts aren't tightened correctly and the rear toe and or camber changes, sometimes drastically. Pretty sad when Harbor Freight sells them.
Michael
Michael
I aligned my car dozens of times while I raced it for four years before it started slipping a little bit. Just replacing the bolts fixed the very minor problem for me. It really is a non issue.
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Yes it does. The eccentrics can move when a high lateral force is applied to them if they are not tight enough. Bolt stretch will cause them to be less tight than they should be, and so they could move. I had a set of regular adjusting eccentrics for front MacPherson struts move because I had them incorrectly torqued to 90 ftlbs. The proper value was 140 ftlbs, and when I tightened them to that they no longer moved, even with track use.
