Boxster track car photos (finally) and towing experience
It's not Spec (BSR) - it was also built for Grand Am (the Randy Pobst threads in this forum have more info, as he drove it at PCA) so it is more similar to the SpeedSource Boxsters. I have an LSD for it, but not sure I will use it or not - two schools of thought on that, and I don't do auto-x so I'm not sure it will help me all that much
Cheers,
Dylan.
Dylan,
I plan to do POC - I'm taking my 987S to Streets in November, and hope to do Time Trials with POC soon, hopefully with a test run with Marty so I can be passed through.
I didn't think of a MAF - don't have a spare that I can bring to the track Tuesday, but I might get one later, or just see if it's merely a factor of a cold engine with very little gas in the tank.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Super Moderator
Needs More Cowbell
Needs More Cowbell
Have you checked the color of the fluid? Does the Escalade have a 'tow' mode for the transmission?
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
P.D.
Just out of curiosity, what type of trailer suspension? Torsen axles? What spring rate?
I don't recall ever smelling transmission fluid in any of my Ford Excursions/Crew Cabs.....are you sure everything is dandy?
It's not burning fluid or anything, just hot metal smell, like brakes but not as strong - similar to the smell of the engine after a long trip. I've noticed that in this car from the start, and it doesn't alarm me, really.
It has a tow mode, which is very efficient - changes the shift patterns, automatically engages engine braking on hills, and allows manual override, plus the suspension is auto-leveling, it has an aux tranny cooler, and a class V hitch. It's pretty well setup for towing for being a soccer mom car.
Here's exactly what happens. When the engine is cold, it surges constantly - vroom, vroom, vroom, vroom, and that quiets down after some driving - not yet up to temp, but a bit warmer. When on an incline, it stalls almost all the time, and there is very little gas in the tank - perhaps just over a gallon total. It doesn't seem to stall on a level ground. It runs really rich, but does not backfire, and when I pulled up to the house for the first time, on the inclined driveway, it stalled just putting it in neutral.
Won't the engine fault codes show a bad MAF? I could head to Autozone and borrow their OBDII.
FYI, the builder of the car thinks it is unlikely to be the MAF - he's convinced it is a vacuum tube loose or disconnected.
You might want to try Mike Essa at Tech Trix Motorsports. His shop is in Anaheim and he's built quite a few of the POC Spec Boxsters. You can call him at (310) 901-6522
Hey Phil,
I'm interested in your suggestion, time share, you know I like that car. Let's take it off line and discuss further. Why don't you come to CMP with us for one last go this year?
