Towing your race car: BMW X5
After that happening to my Chevy Z71 pickup, I'm convinced if something like that happens in these short wheel base SUV passenger vehicles, you are screwed. That boat and trailer rig weighs a lot less than a towed track car in a 24ft covered trailer. People tend to just think of straight line towing power and stopping. You need to think about what happens should an emergency maneuver be necessary. I now tow with a 3/4 ton Crew cab HD.
During the whole episode which seemed to last for hours, I kept thinking, "Are you supposed to steer into the skid while towing just like you normally would?" Apparently, so.
Super Moderator
Needs More Cowbell
Needs More Cowbell
BTW, it is usually mentioned that a vehicle equipped with active (air) rear suspension control should NOT use a load leveling hitch.
As has been mentioned before, towing is rather straightforward....right up until the moment that something goes wrong (emergency lane change, blown tyre, etc).....then you wish you had a proper towing setup, rather than a marginal one.
1 Post
BINGO! Any thing can tow just about anything under optimum conditions. But when the conditions get dicey... That photo of the X5 with that giant silver twinkie behind it would scare the crap out of me if I were next to him on the highway on a windy day...
[/QUOTE]
Ok going of topic here, but why is this. My Nissan Aramada came stock with air suspension. The owners manual specifically states to use a Load distributing hitch.
[/QUOTE]
Probably just stick with an open trailer. Any issues that you guys can think of storing the trailer and car in a secured boat/RV storage area, with a car cover on (besides possible vandalism)?
I towed my 23" Cobalt boat with a 2002 BMW 4.6 is. The towing part was fine, even over the Sierra mountain passes, but I was really glad that I had the extended warranty when the transmission died. The transmission replacement (they don't repair them) was $6,000 +, covered by warranty.
Super Moderator
Needs More Cowbell
Needs More Cowbell
As mentioned previously, I would consider an enclosed Trailex (small, light, within the limits of an X5) before an open trailer (especially if you're talking steel)....for security and stability.
This guy's set-up violates the manufacturer's specs for total weight and tongue weight, and goes against general towing guidelines for wheelbase versus trailer length. (Here are some good guidelines: http://www.rvtowingtips.com/how-long.htm).
The point of these specs is not to protect you under normal towing conditions, its to save your @ss when things go bad. Just like a roll cage, you hope you never use it but you sure are glad you have one when an accident happens.
One big difference however. A roll cage only protects the driver. If you don't use one you only injure yourself. A properly set-up tow protects everyone else on the road as well. I don't care if a guy has no cage, but it seems pretty selfish and irresponsible to knowingly exceed manufacturer's specs and common sense when towing. (And by the way, the spes assume you are using a weight distributing hitch and are properly set-up. There are no special set-ups that magically increase your safe towing capacity.)
If this guy injures or kills someone in an accident he'll be found negligent for towing with that set-up. He'll end up bankrupt, in jail, and carry the guilt for the rest of his life. You can get a proper tow vehicle for less than $10K. Or rent one when needed. Why take this risk?
I knew it wouldn't be long before you asked this on here. Too bad both DS and I lurk here ;-)
